Old 05-20-2015, 09:09 AM
1650noob 1650noob is offline
Default Help! Looking for bottom ISO rubbers
Looking for bottom ISO rubber mounts for engine cradle on 1650.
They are nowhere to be found on the net. I have the upper rubber mounts. just not the bottom.
thx, Nate
Owner of:
cub 1650
cub 122
Old 05-20-2015, 09:28 AM
I do not understand. The ISO mounts are sold as a Kit, which included the Top & Bottom bushings, with spacers and washers.
Are you looking for something other than this kit...??
Old 05-20-2015, 11:09 AM
Well I musta confused myself as I was under the impression the kit only supplied the upper rubber mounts. I'll have to go check again. I did not keep any of the original hardware and rubbers and its been 3 years since I took it off. The ol' memory fades fast.
Thanks,
Nate
Owner of:
cub 1650
cub 122
Old 05-20-2015, 11:15 AM
I'd toss them and go solid mounts. That rubber mount system in the QL's is a joke.
Old 05-20-2015, 11:25 AM
For those of us that know how to install them........they are GREAT...!!!
Old 05-20-2015, 11:38 AM
jimbob200521's Avatar
I must be among those that can't get them right, I wasn't able to get my Quietline right when I had it! And IH must have agreed; the mounting system in the 82+ Series Cubs didn't use them
I have heard rumors about those out there that got em right and I'm still wanting to drive one of em!
-Ryan
Old 05-20-2015, 12:25 PM
Even if they're right, they are still not anywhere near as good as the system on the 1282, 680, 1050..... I do not like the rubber mount system on the QL's. It's not about getting it right or correct, you can't have a motor that is able to move with a flex disc driveline. It's hard on the driveline. The gear drive QL's are the worst.
Old 05-20-2015, 01:00 PM
johncub7172's Avatar
thx, Nate
Nate, Your best bet is to get in contact with a Cub Cadet dealership if you want the correct factory replacement parts. I don't believe the kits are sold any other way but as a whole, so getting just the parts you need might not be possible.
I installed the ISO mounts from Cub Cadet on my 1450 recently. I also followed directions and installed new lock nuts as well. I have since checked the four mounts, and have snugged them down as they seat and wear in a little. The ISO mounts are not a joke, but what is, is what's between some one's ears on this form who needs to be knocked back a peg or two.
Here's what IH had done in making the Quiet Line a better garden tractor. Keep in mind, no matter what some of the yuppies claim, the cast iron transmissions are with out doubt a stronger housing than the aluminum housings found in these so called "super" gts.
Now mind you, IH had been building these garden tractors since 1960, up to the introduction on the Quiet Line models.
ISO-mounts separate engine from frame. Flexible rubber isolators between engine and frame eliminate metal to metal contact so that operating vibration is reduced substantially. The result is less noise and a more comfortable and quieter ride for the operator.
Sure, from what I read, solid engine mounts will work too. But when you actually think about owner operator neglect to tractors, it can be considered why the ISO mounts have a bad rep after 35-40 years of use.
Its like why would CCC use a weak aluminum trans housing and install a stronger fine spline axels? Its makes about as much sense as using toilet paper before you use the john.
Good grief. Don't be scared off by what other members think is a joke.
Old 05-20-2015, 01:11 PM
My 1000 and 1200 both have new Cub ISO mounts as well as rebuilt drivelines and are the smoothest running quiet machines I own.
Just recently tried to save a buck for my BIL and installed the NAPA hard (neoprene?) (blue) mounts in his 1450 along with new Flex Disc joints and they are just awful.
I fail to see how solid mounts would be any better in that regard as the NAPA automotive pieces are damn near as hard as solid, but would like to be proven wrong. I don't think he will like it and I darn sure don't either. Maybe someone at RPRU will have a QL on display and let me see for myself.
Let me know and I'll forward my Phone # to Ya!
What with a 5 year run of close to 135,000 units I would have thought the hue and cry from customers back in the day would have prompted changes from IH concerning this "problem" with the mounting set up on these rigs.
After near 40 years of hard use & abuse, I can understand problems.
I'm tempted next to try the black rubber ones as seen on E-bay for comparison.
Your results, I'm sure, will vary.
Comparing the 2 cly Cubs w/ completely different mounting set-ups is, IMHO, doing the apples to oranges thing and not a valid comparison.
Kinda like comparing a diesel to a gas rig.
Old 05-20-2015, 01:13 PM
Some strong words in there about fellow members, but in the end a lot is opinion and a lot is one person's understanding of a situation vs anothers.
In your post, I see you calling another member (or more than one) a joke. I also see a lack of love for these so called "super" gts while strongly defending the older machines. What that tells me is that all parties involved here are more alike than they will admit. One doesn't have love for ISO's and one is not showing much affection for aluminum rears. Why can't we all just get along! I'm not taking sides here, I have opinions about both issues (tractor opinions, not member opinions ) but I'm going to keep them to myself as I don't want to add fuel to the fire. Let's just all agree to disagree on this one and move along. If the OP wants ISO's, lets voice our opinion about them and then either help him track them down or get out of the tread. Cheers guys
-Ryan
