Transporting a vertical air compressor
Can a 80gal verticle air compressor be drained of oil and layed down to haul on a trailer ok? Or would it be better not to? I don't see what it would hurt if you drain the oil. Any input would be great, thanks! Brian
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
I see no problem if you drain the oil.
we've hauled a few laying down without any issues.
Ive moved a few that size and larger short distances without even draining them...but then again I'm lazy and they were old and we wernt to worried about them. But never had a issue
1872 - 60"haban 54" power angle haban blade '63 Original - restoration project 582 -tiller 147 - leaf duty with bagger. 1811 - Ditch mower 800 - have it just cuz its a 800 |
Thanks guys! I'm didn't figure it would be an issue, but wanted some opinions. The trailer I'm gonna use is not much bigger than the compressor so didn't want to chance it standing upright. Don't know if I'll go get it tomorrow or not, will post some pics. Thanks again!
I don't think laying it down would be an issue. Just crank it through and make sure it is not hydro locked before plugging it in.
122 original, well used. Owned since 1972 2182 new to me. Refurbished and gave to my son. Deere 4300 4WDA HST with FEL Many old Ford tractors, all gone now Couple old Ford trucks |
Piston go down, suck air through intake valve, piston go up, push air out of exhaust valve,be it reed or disc style. prolly a good idea to drain crankcase as lube might find a way to leak out of an atmospheric vent? and good time to change it anyway. just my .02, but so many variables. |
I recently moved mine and I drained the oil from it as it needed changed, it was laying down cause of the top heaviness of it. Once back in place and new oil she fired right up and making air again with no issues!!!
"We don’t stop playing because we grow old, we grow old because we stop playing." |
