Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Onan Engines
Old 06-15-2015, 11:32 AM
elshiv's Avatar
elshiv elshiv is offline
Default Onan Oil Plug?
Hey Guys,
I drained the oil out on my 982 for the first time last night. I realized the oil plug is in a horrible spot! I'd really like to install an oil valve so it's easier to do oil changes! I have 2 I'm looking at but I'm unsure of the size of the actual oil plug. I know I used a 3/4 socket to remove it but that is not what they show on the charts on the Valve site.
http://www.qwikvalve.com/Heavy-Duty-...oto-Valve.html
http://www.ezoildrainvalve.com/industrial-engines.html
Can someone verify what size the actual plug is? I'm guessing it's a 3/8" NPT plug. but I'd really like to make sure I'm ordering the right thing the first time.
Javier~
1980ish 982 w/ 3pt. & PTO /50C deck - a Work in progress. Brinly Moldboard Plow.
I'm a complete noob at this so please take it easy on me.
Old 06-15-2015, 02:22 PM
Well since you have the plug out take it to a hardware store and compare it to different size pipe.
Old 06-15-2015, 09:50 PM
john hall's Avatar
I replaced the plug in mine last year. For some reason I think it had a flange with an O-ring. If so it wouldn't be NPT, possible NPS, not certain. I'm pretty sure mine came from Cub Cadet Warehouse, don't know if Cadet still offers it or not. I remember while draining the oil that it would probably be less mess to either pull the engine or drop the deck and mule drive. Some re-engineering is certainly in order!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 06-16-2015, 09:04 AM
elshiv's Avatar
Well, It's definitely not a 3/8"! I have some 3/8" bolts and nuts and it does not fit.. it's much bigger.
I need to go find my calipers!
Javier~
Old 06-16-2015, 09:08 AM
A 3/8 NPT is not a 3/8 SAE ( bolt thread)
Go to the Hwd/home cheepo or Blows and compare or ask a friend
Edit:
Parts tree shows it as a fine thread headed plug, with "O" ring, as J..
Hall stated.
So caliper and thread pitch gauge will tell you for sure.
It will not be a pipe plug, unless it has been re threaded.
Old 06-17-2015, 07:08 AM
I went to Autozone and picked up a new plug for one of mine.
Old 06-17-2015, 07:23 AM
elshiv's Avatar
Do you know what size it was?
Javier~
Old 06-17-2015, 08:26 AM
3/8" bolt threads and 3/8" Iron Pipe threads (and sizes) are two totally different animals.
3/8" Iron Pipe dimensions:
