what is the best way to remove drive shaft to replace belt that drives the alternator and water pump'
You will have to move the engine forward or the transmission backward. Did you run it hot before you noticed that it had broke?
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
I slide the engine forward. Not a bad job at all. Might be a good time to check the rag joints and drive shaft metal couplers for wear. Since you'll have it apart already, they can be replaced if worn.
Josh Diesel Cub Cadets........... |
yes i did run it about 30 minutes hot before i noticed it, thanks for the info..
That's not good. Hope you didn't cook it.
Is the temp gauge working? With the belt gone, the gauge probably would've pegged high pretty fast. Check it over good. Hoping you didn't crack the head.
I will check it over good, once i moved the engine ahead the belt won't be any problem, thanks again for the info. everyone.
