Closed Thread
Old 07-12-2015, 12:18 AM
Justin Witt Justin Witt is offline
I wouldn't call it being a mechanic. More ingenuity.
Old 07-12-2015, 12:21 AM
I have yet to see a working "Justin Witt" rebuilt clutch.
You will be seeing one by Tuesday. (probably before)
Old 07-12-2015, 12:24 AM
j4c11's Avatar
j4c11 j4c11 is offline
Your profile says "small engine mechanic". You have a website called "Witt's small engine shop" or something like that. You've called yourself a "mechanic" in several posts on this site. I wouldn't call it being a mechanic either, glad you've changed your point of view on that.
Old 07-12-2015, 12:26 AM
Old 07-12-2015, 01:31 AM
Ya nobody would call wiring something being a mechanic. A mechanic is working on mechanical things. Who would have thought? This is being an electrician. Working on stuff that has to do with electricity. Yes the both colide but still are very different.
Old 07-12-2015, 02:06 AM
j4c11's Avatar
Not that different, they have something in common, the fact that you are neither. Which was the whole point of my post, that you're getting ahead of yourself, first by calling yourself a mechanic, then by trying to charge people for something you know nothing about. But that part is still unclear, in the first post you say "I can give you the cost then too", then in post number 4 you say "I'm not selling anything". So while you fail at being consistent, reading comprehension, respect for others, modesty and spelling , you get an A at trolling. Good luck to you sir.
Old 07-12-2015, 08:21 AM
Justin, FWIW:
A coil to work properly,should be wound on a jig or a bobbin paying attention to the number of turns and the gauge of the wire of the original coil.
The coil of wire is then dipped in "Varnish" ( today we use epoxy and it is cured in an oven)
This is done to secure the winding's into a homogeneous unit as vibration will chafe the wire shorting or fatiguing it, causing an open.
Splices in the wire are not acceptable it should be a continuous piece of new enameled wire of the proper gauge.
Used wire is not acceptable.
Just to give you a quick approximate idea of how it is done.
BTDT.
Old 07-12-2015, 08:42 AM
You are 100% correct.
Old 07-12-2015, 10:28 AM
I'm done. Just done. Jon, your not going to be getting an update whether it works or not. I'm done.
Old 07-12-2015, 11:13 AM
cubs-n-bxrs's Avatar
Justin oh Justin you just make it to easy for people to dog on you. Must be you watched some Jack Wagon on youtube rewind a PTO and now you are going into business rewinding. You're killing me. LOL
Closed Thread
