Old 06-07-2015, 07:46 AM
neilh419 neilh419 is offline
Got the carb. Adjusted again this weekend. The 1641 is mowing great! Whenever I shut PTO off it still wants to miss, or fire a little bit, but only at open throttle. I adjusted it just barely over idle. It will run there, or about halfway up perfect. Was looking at a manual, and I might be missing a spring. Perhaps I dropped it when pulling everything apart.
It's #4 in this pic.
Old 06-07-2015, 08:10 AM
http://www.partstree.com/parts/cub-c...gine-assembly/
Not sure if you need #47 or #48
Old 06-22-2015, 11:52 PM
It's been a couple of busy weeks, and I haven't had a ton of time to fool with the Cub. I rechecked the carb to be sure there was no junk in it. Readjusted it as well. Still idles well, and runs under load well. I'll keep searching to see what I can come up with.
Will it hurt the tractor to continue using it in this shape? As I've mentioned it only seems to fire through the exhaust at wide open throttle with no PTO load.
My next stop will be to check the intake gaskets again, maybe I got one backwards, or something. Scratching my head over here, but where there's a will there's a way...
Old 07-04-2015, 06:07 PM
I keep tinkering, but I still have to use this tractor too. It's been mowing well, as I said last time. Was mowing today, and the blades just cut off... Stopped... I drove it to the house, and shit it down. I'm thinking it might be the PTO switch. When I tried to restart it, the fuel shut down solenoid doesn't click back, again.
I'm the shut down solenoid were the issue, the tractor wouldn't run. Maybe, if it thinks the PTO is on it just won't try to start. I'm not "allowed" to work on it today. Promised my wife I'd be around for dinner...
I'll check the wiring diagram, and be back at it soon! I'll give update when I can.
Old tractors, and old cars. Fixed the power steering on the van yesterday... I'd rather work on the cub.
Old 07-20-2015, 06:07 AM
I'm an idiot. Dead battery.
Old 07-20-2015, 07:41 AM
Thats ok,
sometimes we all overlook the simple things or we "assume"
Tags
1641, lose power, pro, smoke
