Old 08-01-2015, 10:17 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
I can get a tube for about $12 at my local hardware store.
I lost track of what I own a long time ago!
Old 08-02-2015, 10:03 AM
Nice looking tires, though I like the tri-rib skinnies on the front. As far as the tubes go, I run tubes in everything that I have when I put new tires on, whether or not they are tubless. My reasoning is that after owning several cubs and seeing the corrosion that takes place on the rim from the moisture in the air over time, it only makes sense if you plan to own the cub for a long time or want to sell it in good faith as a dependable machine that will last someone for a long time.
Old 08-02-2015, 10:15 AM
actually tubes speed up the rusting of the inside of the wheel, as you drive the tube moves around and rubs the paint off the wheel exposing the bare metal.
Old 08-02-2015, 12:20 PM
rwairforce rwairforce is offline
Yes, $12 per tube times 4 is near $50. I got 4 of them. Oh well, it's done and they work so what's not to like. As I said earlier, $50 over 15 years or so isn't too bad. All good here.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-02-2015, 10:54 PM
I respectfully disagree. I have seen tires removed with tubes and without tubes. The ones with tubes have looked better every single time, whereas the ones without tubes flaked off chunks of rust from the inner hub of the rim. One guy who does nothing but tire changes and has for the past 40 years told me the same thing.
Old 08-03-2015, 12:08 AM
And I respectfully agree with you. The reason some put tubes in the first place are because the rim is already so bad that you would never get the bead to seat without them...
Old 08-03-2015, 01:39 PM
Group_44's Avatar
Group_44 Group_44 is offline
I took a look at the V61's I have that are going on one of my Supers, I know they are a different size but the side wall is marked "Tubeless". What are yours marked? I only mount tires with a tube if they won't hold air without one.
2082 w/60" Haban Deck & 450 Blower,AGs,weights
2084 w/54" Deck & 451 Blower
2086 w/54" Deck, 54" Haban Snow Blade
1864 w/54" Deck and weights
1641 w/48" Deck
1650 w/44" Deck parts Tractor (getting smaller all the time)
445 John Deere w/ model 40 FEL (went over to the dark side)
Old 08-03-2015, 09:31 PM
Ah, I neglected to account for the 4 tires. Continue on Sir.
Old 08-03-2015, 10:57 PM
Thats funny... I will "continue on" as long as I can and thank you kind sir...LOL!
Randy
John Deere 140 H3
Sears: GTV16
