Do you know if it ever got towed? That's the #1 reason a pump would lunch itself. Sometimes they can be rebuilt, if nothing cracked. But since they are relatively plentiful and inexpensive, replacing it is probably your best option once you go through testing all the easier "could be's." Good luck!
Ian Mine: 72 w/ k301, 3 125's, 1 w/ hydro lift, 38,42, & 2 48 decks, 2 42 front blades, QA-36a & QA-42a thrower, tiller, lo-boy 154. Also, LOTS of parts. family's:2 105's, 2 106's, 149, 2 lo-boy 154s, Farmall Cub. Non-IH: 1940 JD Model A, 1954 JD 40 U, 1955 JD 40 Crawler, 2 1956 JD 420 U's, both w/ Henry Loader and Backhoe. JD 110. Wheel Horse (model unknown.) Power King 1614. We love our tractors!
Thanks all, I looked at the manual on how to decouple the tractor, I am tossing up whether I should do a filter/oil change or just rip into it and get the pump off, I don't want to waste a new filter and oil. I noticed today that the rear shaft on the pump was spinning but the tractor was going no where with about 1/4 throttle and half forward on control lever. As soon as I find out the problem after getting pump out I will re-post here to show you all what crapped out
Cub Cadet 1968 105 with Spring Assist & 3 point Hitch 42'' Mowing Deck QA36 Snow Thrower 42'' Tiller Snapper 1983 LT1100 ![]() 1967 Mustang Coupe RestoMod
Drain the oil, if you find metal when you drain the oil then I wouldn't bother to change the oil and filter until you find out what failed and repair it. If no metal then go get a NAPA1410 or Wix51410 filter and some hydro oil from Wally world or TSC and do a change. If that doesn't get it going drain the new oil into a clean container so that you can reuse it. At this point you don't have much to lose. The fact that the shaft coming out of the back is spinning and it's making bad sounds is not a good sign.
A towed (?) tractor's hydro...This one locked up when the slippers got crammed against the housing and cracked the housing.
Would normal hydraulic oil work or does it need to be marked hydro static trans on bottle?
I buy mine at TSC. It's equivalent to HY-TRANS Plus (MS-1207), the recommended hydraulic fluid for IHC
http://www.tractorsupply.com/tsc/pro...ic-fluid-2-gal |
Ok I just did a oil change and new filter and so far it seems to be all working again. I could not do a big test because it was late and the neighbors might get upset if I started to hot rod around the yard on a Cubby. The filter was damn tight to get off and I removed the back diff cover to drop the oil, there was a fair bit of jelly type stuff which seem to melt when touched, I also think the filter was half blocked from this god knows how many years of this jellied trans oil.
Big thanks to Ford4150 for steering me towards the right oil to get, I will run this for a week I think to let the new oil wash around and then maybe do another oil/filter change just to be safe, at 18 bucks for 2 gallons it's not going to break the bank. Thanks to every one for their much appreciated advice, now I can move on to other little things to fix on it. Here some pics of the rear end, the plate clearly shows where the level has been sitting for many years. ![]() ![]() and the bad boy ![]() and the next fixes needed ![]() ![]() New seat coming this week
Glad it was an easy fix.
You should think about a hydraulic lift for your thrower and tiller
