Old 08-24-2009, 07:26 AM
mikeut01 mikeut01 is offline
Unhappy spindles and bearings
where can you get new spindles and bearings for that deck i have one but cant use it
Old 08-24-2009, 10:48 AM
squatch squatch is offline
I would start with the sponsers on the top of the page or your local cub dealer. That's where I got my seals. The spindles are rebuildable. Not much to them really. a bearing top and bottom and seals top and bottom. Rest is just housing, spindle and spacers.
Old 09-30-2015, 09:56 PM
IH1650Cub IH1650Cub is offline
Where did you get the belt guide??
Old 10-01-2015, 05:55 AM
You do realize this thread is over six years old and the OP hasn't logged in since May 2015.
Old 10-06-2015, 01:29 PM
alsparl alsparl is offline
Ah, what's 6 years? I would like to see the OP would jump back on here and let us know how his deck has been since then.
Aaron
'83 782 #723927
****original KT series 1 engine
****added dual hydraulics from older, donor 782
'04 SRC621
'95 Magnum (M18S) spare engine
****spec 24646
****s/n 2507913316
Old 05-02-2016, 09:31 AM
samckitt samckitt is offline
Did a search & found that these are replacements for OEM Cadet part number.
http://www.agrisupply.com/cubcadet-mower-blade/p/45724/
Anyone have any recommendation for a blade with more lift to fit the 50c deck?
Thansk
________________________
Scot
Old 05-05-2016, 11:09 PM
Sprint60's Avatar
Sprint60 Sprint60 is offline
Since this old thread has already been returned to life, I'm curious to know if anyone (especially the OP if he's still around) has any comments on the graphite paint used; has it held up well? Does it perform as expected? Does cut grass stick to it and is it easier to clean than standard paint?
I'm working on a 48-inch cast nose that'll be getting some paint in the next couple weeks and I'm still not sure what to use underneath.
147 w/Electric Lift - the tractor that says "Ni!"
147 w/no lift at all - the tractor called "WallE"
QA48 deck, 1a tiller with one extension, QA36B snow thrower, QA42 blade
and various other bucketraters, grassenators and dirtavators.
Old 12-06-2016, 12:53 PM
Sorry folks I haven't been on in a while. Still have the Super and use it all the time.
I wouldn't use the EZ slide paint again on the deck. It has pretty much worn away. Next time I'll try an epoxy coating like this.
http://www.tapplastics.com/product/f...with_kevlar/30
I used that on the bottom of my river jet boat. It's very slick and tough stuff.
The gator blades held up fine. I really haven't done anything to the deck since this thread except clean it yearly and sharpen blades. It's about time to coat it again.
Old 12-06-2016, 10:30 PM
Nightow1 Nightow1 is offline
anyone ever use them on Haban 60"? was thinking of getting them but wasn't sure how they performed???
Old 12-09-2016, 05:32 PM
Pretty much the Gator is a mulching blade for things that don't have mulchers. Without a mulching plug for the deck it just works like any blade.
It is also heavier(thicker) than stock and hardened steel. Hard to sharpen by hand but holds an edge for a long time.
