Old 07-14-2010, 07:32 AM
nikster's Avatar
nikster nikster is offline
Default High temp. paint question?
My wife was looking at my muffler. Well not my muffler but my # 109's muffler. She thought it looks 'ICKY'. It does but solid as can be.
Question to anyone?
Will High Temp black, paint work on it to spiff it up a bit? The one that they use for engine's?
Or how about the paint for BarBq's?
Or will I be starting other issue's?
Thanks,
Nik
Old 07-14-2010, 08:15 AM
TEET's Avatar
TEET TEET is offline
I've had good luck with bbq grille paint in the past on mufflers. It may need re-coating once in a great while, but it holds up pretty well for a working tractor.
I have also used VHT paint on several exhaust systems as well. Most recently on a 72' Honda CB750 4 into 1 Yoshi header and so far it has held up great.
Thankfully this place (link below) is 20 minutes from my house, as I don't think you can just stop down to the auto parts store and pick this stuff up. I also used the engine enamel on a few CB's that I have restored over the years, and it holds up very well.
http://www.caswellplating.com/vht/vht_high.htm
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-14-2010, 08:22 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Question to anyone?
Thanks,
Nik
at least she wasn't complaining about your exhaust fumes... :biggrin2.gif:
Gary
Old 07-14-2010, 10:42 AM
Old 07-14-2010, 11:58 AM
nikster's Avatar
Got it off.
Solid as can be, seems to have been re-placed maybe 5/8 yrs. ago?
Brush off the rust & paint? <OR>?
Old 07-14-2010, 12:52 PM
TEET's Avatar
Got it off.
Looks pretty solid Nik, I would remove it, wire brush it down real good, and paint away. Clean up the area where the pipes slip together and re torque the clamp down ...hopefully eliminating the tiny bit of an exhaust leak that it looks like you have.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-14-2010, 12:53 PM
That muffler is probably 25 years old at least and might be original. Newer ones are painted black, I think.
Old 07-14-2010, 07:27 PM
lowlyfzlucky's Avatar
lowlyfzlucky lowlyfzlucky is offline
Matt- I just painted mine yesterday with 1200 degree grill paint (Rustoleum). I used a wire wheel on the grinder to clean it up. It painted up beautifully, but I can't testify to how long it will last. I really liked the paint.
Eric
1450 in progress..........
Old 07-14-2010, 10:32 PM
My local advance auto parts carries the VHT Ceramic paint. This stuff is great.
I did 2 mufflers last year with it and they still look great. I just wire brushed the mufflers good and put a couple of coats on them and then followed the directions on the can about warming up and cooling down a few times.
