Old 03-29-2012, 10:59 PM
silverthornethan silverthornethan is offline
Default Battery
How long whould a battery last running the motor and fuel pump without a generator? I'm only doing this because I don't wanna build a guard for pulley. Thanks guys
Old 03-30-2012, 08:39 AM
Well that is dependent on what you are talking about.
If the engine has a magneto and gravity flow fuel, it will run till it runs out of fuel, or has a mechanical problem
if it has a points/coil system, till the battery runs down and that is dependent on how large the battery is.
I could go on and on but I think you get the picture.
Old 03-30-2012, 12:34 PM
It is a points and coil system. I was wondering how many passes I could get out of a battery before it would need recharged?
Old 04-05-2012, 09:04 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
about 13 or so years ago I built a stocker with no charging system and a ring gear starter, biggest draw it starting it. I had a good quality L&G battery in it and never questioned weather or not could make a run or not. I did try to keep the number of startups to a minimum.charged it the moring or night before an event. in my PS/SS I run a small motorcycle battery ,. it runs a holley pump and the ign. system and one other item. charge it at the start of a weekend .
Old 01-11-2016, 08:51 AM
bschmittling bschmittling is offline
Attachment 22987
Which motorcycle battery do you run? Any recommendations. I am looking for one for my puller.
Thanks
Old 01-11-2016, 11:43 AM
You guys may find this info useful, 16 volt batteries.
http://www.hotrod.com/how-to/interio...olt-batteries/
Old 01-11-2016, 12:11 PM
I had a 100 that didn't charge and I could mow for a month before the battery wouldn't start the tractor.
Old 01-11-2016, 06:53 PM
Same here with my 108, was just lazy to not fix it because the WF v/r's are a pain in the poo poo to get to and adjust
Old 01-12-2016, 08:27 PM
125 cubowner's Avatar
125 cubowner 125 cubowner is offline
I have run a Deka ETX30 all season and probably run it next season also just keep it charged and charge it before each event and you won't have an problems
Doug Richmond Va
1965 Cub 100
1969 Cub 125
1971 Cub 127
1973 Cub 108
Old 01-18-2016, 02:43 PM
dvogtvpe's Avatar
I like the sealed batteries. you an tip them on their side, upside down whatever you want. I lay mine on its side under the rear end to keep the weight low in the chassis. I like to think of the battery , fuel pump ect.. as a weight. if you can put it where it is an advantage its a bonus
