Yeah run it till it takes out your hydro lift lines and causes more damage.
just my 2 scrambled eggs
Right on Lew!!
Looking at that shaft again I have to agree with Lew. It is going to fail and if the shaft gets whipping around it will do a lot of damage. Fix it properly now before it gets much more expensive. Have Jeff in PA build you an improved coupler with the set screws and the spirol pin like the one in this thread (post #28)
http://www.onlycubcadets.net/forum/s...679#post355679 and it should be good for many years.
Thank you Sam I sent Jeff a PM asking if he can help me out
Just to make sure that you understand what I said, You need the replace the pump input shaft or the complete pump in order to have a viable driveline.
this is the shaft,can you dig it?Shaft!
Yes I understand I need to replace the shaft. I'll be looking on eBay for said shaft .
Here is a member selling a hydro from an 181i, he also has one from and 1864 that would work but you would need to convert your drive shaft.
http://www.onlycubcadets.net/forum/s...718#post361718
Thank you Sam I think ive found one local if I can get a hold of the owner. But Thank you for keeping me in mind
