So forgive me if stupid question, never had a hydro drive tractor on hilly property before. But when going up hill, forward speed slows down, without noticing a change in engine speed, its not bogged down. Is this normal?
Thanks |
How much does it slow down?
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Yes !!------- it does not have a "cruise control"
Does it speed up going down hill as well? Sounds to me like it's time to overhaul the trunnion.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
Enough that I think "why is it going so slow". ????
I get that, but has a lever that controls speed, & it isn't moving & engine isn't bogging down like it would with gear driven. Not 100% sure how this hydro setup works, does the fluid pass through gears to give the forward movement? Is there enough gap between gears & housing that it is bypassing the gears?
Haven't noticed that like I do going up hill.
Here is a good understanding of how it works: Read it through ![]() http://inspectapedia.com/heat/Sunstr...msn_Manual.pdf |
Slows down quite a bit up hill, and does speed up going down hill.
