2082 needs work to do work
Well as some of you may remember, the cubs and I recently moved. The wife insisted on coming, so I said what the heck. Anyway, while we were moving I went to start the 2082 to put it on the trailer, and no go. No fuel. Towed it on the trailer. So now we're kind of settling in, and I need this tractor as it will mow much more comfortably than my 1650. I got the 2082 running, but very poorly. So, it's time....
Here are issues that need addressed: I need some help with these. 1. Carb needs rebuilt. I've never done this. I have the manual printed out in a binder, so I figure it's in there. Follow the instructions, right? Is this all I need? http://www.ebay.com/itm/Carburetor-R...oAAOxyXDhSlVah 2. Remote oil filter is leaking from somewhere near the filter. Should be easy to find once I clean it up a bit to see. 3. Ignition switch doesn't kill the engine. This is new. As in a week ago. This tractor sometimes didn't like to start and you would have to wiggle the switch. So when I moved in I took it out, cleaned all corrosion off and put a dab of electrical grease on each connector. Cleaned the harness also, but the black wire had obliviously got hot at one time. Melted the connector a little. I secured the wire and plugged everything back in and it's worked since, no issue. Not sure if these things could be connected. 4. Bendix not going out. I pulled the shroud to get to the starter. Manually pulled the bendix out, and hit it with the smallest shot of WD-40. Worked so far, no issue. It usually would hit once out of 10 turns of the key. I'm leaving the cover off for a bit to make sure it keeps working. |
While you have the tins off check the head gaskets for signs of leaking, good luck with the project.
So this is the carb I have. It's a walbro. Looks to be adjustable. This is a good one correct, not one of the non adjustables. That leads me to which carb kit I need. I'm not sure to order the PN/ KH-25-757-02 or PN/ KH-25-757-01 kit.
Yes, it's adjustable. A good Walbro.
You need kit 25-757-11. It will have all the gaskets you need to mount the air cleaner and the carb. Plus, it's the one for that carb. |
Thank you sir.
