Old 05-05-2016, 02:22 AM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default Oil Line routing, 1872
Hello. I am reassembling a M18 on an 1872. I marked the lines when I took them off ("A" line to the bottom port on the engine), but when I looked at the service manual when putting it back together it said "upon reassembly of the oil lines to filter, the top line on engine port goes to "A". I am wondering if the PO had the lines on wrong. I would greatly appreciate any advice.
Thanks,
Earl
Original, 1512, ih 982, ih 682
Old 05-05-2016, 03:02 AM
I would say it is far more likely that someone crossed the lines than it is the service manual is wrong. But, it has happened.
It's simple, the pressure goes to the outside of the filter first, returns through the center. Plumb it that way.
Old 05-05-2016, 07:11 AM
Inactive Member
Just curious, where in the TP-2204B Service Manual does it say that..??
Old 05-05-2016, 08:17 AM
Ewilliams's Avatar
I found it in this manual that I downloaded here, Manual - Chassis Service 1050, 1204, 1210, 1211, 1810, 1811, 1572, 1772, 1872, & 2072, page 1-40. I just looked at the kohler service manual you referred to and it showed a diagram of the "A" line going to bottom port. Let me know if I am reading it wrong.
Thanks,
Earl
Old 05-05-2016, 08:40 AM
Inactive Member
In looking at page 1-40, of the Chassis Service Manual, the depiction in Figure 12 is correct. Bottom and top are relative to which way you hold the Oil Filter Bracket. More accurately would be, the center port and the outer port. The outer port being A (pressure), and the center port is B (return).
Old 05-05-2016, 10:38 AM
Earl,
If that was the 1872 on cl last week you got a heck of a deal!!
Up to 530 and counting...
