Haban (cub 374) 60" deck on 1572
I am looking to install my 60" deck off a 982 on my 1572. I am missing the rear stabilizer bar ( looks like a "T") and pin that go through the brackets on my frame and rides in the saddle on the rear of the deck. Can I mow without it or will it move around too much and hurt something else. Thanks
149 Raised Bed Tractor 1512 Being restored 1450 Missing its heart Original 1961 Fenders, BB36 and Creeper 1810 Diesel Project, Kubota d905 1572 Diesel, 3-point, 60" Haban Deck Original 1961 Red No options 782D Missing Engine |
Not to be a smarty pants but its supposed to be there for a reason. Those decks put a lot of strain on the mule drive, lift links, gauge wheels etc. Never had any dealings with a 1572, just relating what I have observed/repaired on my 982 and 2072, both with Habans.
By the way, how early of a 60" deck do you have? The one on my 982 doesn't have front gauge wheels, puts a lot more weight on the tractor when mowing when compared to the 2072 with front gauge wheels.
Mine does have the front casters
When I got a 60" deck for my father's 1872, I was in the same situation. I first fabricated the pin myself using a piece of stainless steel rod from mcmaster-carr. It wasn't that hard to do. The t-bar took a little longer to locate one. I ended up getting one that needed to be built up since it was worn at the up-right part of the "T" that slides between the brackets and is captured under the pin I fabricated. When all done, the deck hooked up fine, however it initially would eat the drive belt that went from the tractor to the main drive pulley, in one mowing. The pulleys on the mule drive needed to have their alignment tweaked so walls of the pulley lined up with the belt path.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
I don't have a t bracket but I have the rod pm if your intested
Try the sponsors at the top of the page. I sure it could be reproduced if you had access to one nearbye to copy it.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Thanks I will check with them
