K-161 that's sat
Well I got my O home and have tinkered with it some. I tried to turn it over with the push button and no dice she doesn't crank. So my push starter must be toast. I jumped terminals at the starter and it cranks. Also no spark so I'm guessing points etc. also the motor turns over very easy by hand. It has sat 9 years and the ol boy told me when he got it in 1977 from the original owner he couldn't get it running and that's why he got rid of it. So he then in 77 pulled the head it had a stuck valve he cleaned things up put together and it ran perfect. I'm thinking this is the case again. I went to dump some oil down the plug hole and it took barely any and I could almost touch it . So I'm thinking it's stuck. This has sat indoors the 9 years and I think he was very honest and would have told me if it had other issues. He reassured me it wouldn't take much to get it going. What's your input
If a valve was stuck open, oil would run out the muffler or the carb if you filled the cylinder.
Does the piston go up and down? |
I'm not sure
Didn't get to look to far into it but I dumped a splash of oil down the plug hole and it didn't hold much at all
That just indicates that your piston is currently very close to TDC.
Hmm that doesn't make me feel to good about being able to spin the motor with ease :-) maybe I will pull the engine off and have it looked at
