Old 08-03-2016, 05:45 AM
twoton twoton is offline
there's like 4 or 5 other really simple things that can cause no spark
So let's hear them then. We would all benefit more from that kind of useful info from you than for you to put such effort into giving someone a dick stomping for not saying exactly the right thing.
How about, "yeah it could be the coil, but I'd check blah, blah, blah, first" and then lead the guy through a diagnostic?
Old 08-03-2016, 09:22 AM
I do not recall reading in any of the threads about the steering rod should have a bolt with a hole in it and the nut that goes on it should be a castle nut (shaped like the top of a castle) and then a cotter pin should go in the hole to secure the nut onto the bolt. No, this is not essential to have this set up and a bolt and nut will work just fine. Just an FYI as our young enthusiast learns.
Enjoy that cub....
Old 08-03-2016, 10:15 AM
Ok Jon-I'll spend my parts money with Charlie then, cant beat his sevice.
I am tired of going past the pitbull Jon at the door of this place.
Been bendin wreches pro for 31 yrs minus a couple at the parts store when i blew my rotator cufff, my 1st mower was a broken down dynamark i got going when I was 9, but what do I know.
Old 08-03-2016, 10:54 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Jon need some love guys, just kiss the bull...The choice is yours!
Gilles.
1963 100 (red)/in storage
Old 08-03-2016, 10:33 PM
sawdustdad's Avatar
OK, I'll risk it. No spark. In order of likelihood (most likely to least likely).
At least this is my routine for troubleshooting.
No spark verified by pulling plug and grounding it while cranking.
1. check for 12v at positive side of coil with ignition on. If good, then
2. check for dirty points. clean with some sandpaper or a points file. (80% of the time, this is the problem).
3. Verify continuity from the points lead to a good ground when points are closed.
4. Still no spark, replace the plug (just had one yesterday that was faulty).
5. Check plug wire continuity. Replace/try another.
6. Check coil continuity and resistance. If in spec, replace condenser. If not, replace coil.
OK, I checked 5 things before I got to the coil.
Old 08-04-2016, 06:39 AM
sawdustdad,
Good write up there! Thanks for taking the time to do that.
