Old 08-12-2016, 06:34 PM
Sounds like it will be a rebuild the rebuild.
Old 08-12-2016, 07:18 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
surprised no one noticed allot of crankcase pressure or excessive vapor ? when you had the head off no one noticed scuffing in the liner?
Old 08-12-2016, 07:25 PM
When he got it all together it wouldn't turn over, it was locked solid so the dealer told him to drag the tractor up and down the road to pop start it but all it would do is drag the tires.
I laughed hard about the advice. I laughed harder that he actually tried it.
Looks like you found it Tim, good info to know. That piston looks roached.
Old 08-12-2016, 07:38 PM
Surprisingly the liner doesn't look to bad. since my dad had shoulder surgery all the work has been done by his helper and while he's good at turning wrenches he's not a master mechanic by any means, I wasn't around when the head was off the first time so I didn't get to see it. The engine will get all new liners and pistons and we're going to have the crank ground since the supposedly new bearings didn't look very good.
