Old 08-19-2016, 02:29 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Idk what it is, but aux hydraulics and cat 0 on a low hp cub intrigues me. Probably because you never see it but any way, good job! Running hard or soft line?
1- 1200 in pieces
1- 1864 in pieces
Old 08-19-2016, 04:45 PM
Soft line out of the valve down to a tee and then hard line from there to the couplers. This 1211 had more than enough power for the moldboard and I really want power angle for the winter, I don't have any plans for the rear ports yet but I thought it was foolish not to install them while I was doing the rest of the work. Just getting it ready for my R bucket.
Old 08-19-2016, 04:58 PM
twoton twoton is offline
You fabricating the controls for the valve?
Old 08-19-2016, 05:19 PM
Yes, the only reason I haven't done it yet is because I wanted to finalize the lines first to make sure I wouldn't have to move the valve.
Old 08-20-2016, 02:39 AM
Rescue11's Avatar
Good answer Tim! i have never had a power angle blade. But i have to guess they are the $#!*
1- 1200 in pieces
1- 1864 in pieces
Old 08-20-2016, 09:02 AM
Me either, last winter was my first with hydraulic lift and it was awesome but I still had to get off and turn the blade, not this year.
Old 08-21-2016, 10:23 AM
Rescue11's Avatar
Well its kinda like a virus, hydraulics that is... Hydraulic lift, then hydraulic outlets, and then you run a machine with power steering. Before long your re designing the three point and trying to figure out what other attachments you can make hydraulically operated.
1- 1200 in pieces
1- 1864 in pieces
Old 08-21-2016, 10:53 AM
BTDT.
2,782's & 1650 cubs, all with power steering.
A Farmall 400 with a vintage Wain-roy backhoe off a Hough payloader.
They earn their keep.
Old 08-21-2016, 10:38 PM
A rear IH back blade or the rear rake comes to mind....
Up to 534 and counting...
Old 08-22-2016, 12:28 AM
Hydraulic turn on a push blade... Priceless!
