#41
So... I have been working away from home on 7 12s for the past couple months which doesn't leave much time, none, to work on my projects. I hope to get back at it again soon!
Just found out though that the 1811's mower deck is only cutting on one side. I haven't been able to check it out myself (see above) but I want to go ahead and order new belts that I can install when I get back. Anyone know what I will need to order for a 44 inch deck? |
#42
Should be able to look up the part number on Cub Cadets web site. Look under parts and service.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
#44
Yes, this is correct. Look up the parts yourself. Very easy to do. Follow the prompts. If it is only cutting on one side, you better look before you order parts. No way that the blade on only one side is spinning. Check to see that you (or whoever) didn't install a blade upside down. Also make sure all the blade spindles will turn by hand (engine off). If the deck drive belt was broken, the center blade would be the only one spinning, not an outside one. |
