Old 08-26-2016, 12:52 PM
Haven't made much progress lately, with everything that's been going on there just hasn't been time. I will be setup at the local fair all next week to promote the powder coat business so it looks like it's gonna be another week, I did put all the lines coming off the spool on hand tight and test fit the gas tank to make sure it clears and it does by about an 1/8". Next week is gonna be a long one, I will be working my normal hours at the shop and then I will be up at the fair for another 5hrs.
Old 09-18-2016, 04:59 PM
twoton twoton is offline
Originally Posted by twoton View Post
You fabricating the controls for the valve?
Any progress on this Tim?
Old 09-18-2016, 05:03 PM
Not to much, turns out I know somebody that's an amateur machinist and he made me these parts which will eventually become the levers for the valve.
Old 09-18-2016, 07:42 PM
Dirty Steve's Avatar
Looks awesome. Can't wait to see the rest.
Old 09-19-2016, 04:29 PM
That is awesome, Tim!
Old 09-19-2016, 06:22 PM
inspectorudy's Avatar
"Well its kinda like a virus, hydraulics that is... Hydraulic lift, then hydraulic outlets, and then you run a machine with power steering."
Yeah, it's called a John Deere 318!
1811 Hydro
Old 09-20-2016, 07:17 PM
Got some work done today on the handles, I decided to go with round stock for the handles which I will thread and put handles on.
Old 09-20-2016, 07:59 PM
Coming along nice , If I may suggest, add circumferential gussets to the levers where they are welded.
Easier now then later when they break
Old 09-20-2016, 08:11 PM
I drilled into both pieces so the handles went in until they bottomed out on the cross shaft, I didn't just weld the rod on. I tested them out by putting them in a vice and I was pulling hard enough to start tipping the bench, should be plenty strong.
Old 09-20-2016, 08:20 PM
That should work well then.
I had not anticipated you drilled pockets.
