Old 09-25-2016, 04:19 PM
Merk Merk is offline
You guys ever think of looking at the parts books??
Took me all of 30 sec to find it
That bolt is supposed to be a 1/2 x 1-3/4" w/hex lock nut
The bushing/spacer goes in the upper hole for the crank handle clevis
The spacer is 1/2" I.D. x 9/16"
Available from Brinly/Hardy
https://shop.brinly.com/assets/image...am_PP-51BH.pdf
I suggest you look for the red arrow in post #4 on this topic. Look The hole in question has part number 29 (bolt) going thru the hole.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 05:23 PM
garynail garynail is offline
Default I'll get some pics
Can you post a picture of your plow?
I like to see a picture of your plow point and hitch adapter.
Can you post a picture of your plowed soil?
What type of soil are you plowing?
How many rounds have you made. First round should go around 2-4 inches deep.
Second round should be better
Third round should be the money maker round.
Is it sod?
I'll have to take some more pics. There is 18" between the rear tires so I have it in Hole 2-R per the chart I found on-line. I'll have to try it in 1-R as the Brinly manual states though. I raised the left side onto 3 2x6's to simulate the proper angle. Set the plow so the landside is aprox. 1/2" off of the ground when the point is touching. These three pics are all I have right now. When fully raised the point is about 3-3/4" off the ground. You can see the plow appears to be too far left in the last pic and the landside is setting too high IE the plow is not deep enough, but setting it to run deeper makes it worse. BTW the right wheel is in the furrow from the first pass. I know it looks like I am trying to cut sod there, but it was a tilled garden last year and the soil is very soft and sandy so that should not be an issue. Is the furrow wheel weight going to cause me an issue? being so large?
Old 09-25-2016, 05:34 PM
You have the point set way too far down. (Trying to plow too deep.) Rock the point up... like, a lot.
I'd also suggest taking a flap disc on a grinder and taking the paint off the share and most of the moldboard.
Old 09-25-2016, 05:36 PM
You have too much point. The landslide should be no more than 1/2 inch above the bottom of the furrow.
Adjust the crank so the plow point is closer to the frame.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 05:44 PM
Default I'll give it another shot
Thanks for the replies. I'm looking forward to getting it running properly. Thanks again, Gary
Old 09-25-2016, 05:46 PM
Here is how your landslide should look when set right.
The landslide is against the bottom and side of the furrow.
The plow is not a Brinly plow. This plow has a Homelite decal on it
I own 4 different brands of plows before anyone ask.
Project Uncle Dick
Cub Cadet 70
Old 09-25-2016, 06:35 PM
I did!
I saw!
And that the first line I posted!
Look at the parts list!
The spacer you guys are talking about is the one I posted also.
Old 09-25-2016, 06:45 PM
I did!
I saw!
The hole in question is NOT the one with the bushing.
Old 09-25-2016, 06:49 PM
Default I'm not sure what you are talking about...
There was never any question about the bolt being 1/2" x1-3/4. That's pretty easy to figure out even without the manual or parts list. I never asked if there was supposed to be a spacer there. I asked if that hole was supposed to be slotted of if it was worn. Thank you for taking the time to try and help.
I did!
I saw!
Old 09-25-2016, 06:59 PM
I give up, Someone mentioned a spacer.
I was merely pointing out the spacer goes in the upper hole
it was a FYI moment
The bolt pictured by the PO was obviously TOO SMALL
Just thought I'd look up THE CORRECT SIZE BOLT> period.
Geesh
back to your original programming.
