Old 10-22-2016, 02:31 PM
tmx43 tmx43 is offline
Default Brinly plow to hitch advice
I have a brinly plow and a cub cadet original hitch.what is needed to stop the side movement of the plow.it will move 90 degrees right or left .I know the newer sleeve hitch is made different with bolts but my sleeve hitch is the old wishbone style. thanks for advice.
Old 10-22-2016, 11:34 PM
PSully PSully is offline
First of all, welcome aboard!
The best thing to do is to post a picture or two so that everyone has a better idea of what is going on with your setup.
Old 10-22-2016, 11:55 PM
He's talking about a Brinly "Y" style adapter.
I am not sure that there is anything you can do about it wanting to swing that far, outside of modifying it......
You say it swings 90 deg. I'm wondering if either the hitch on the plow is worn, or maybe even the adapter. I don't think they were supposed to let it swing that far.
Old 10-23-2016, 09:03 AM
Merk Merk is offline
Here are some pictures of the early system to control side movement.
Here is a picture on stabilizer plates:
The early sleeve hitch attachments were only a single hole set up. This set up may be able to be modified to work on a 3 hole sleeve hitch system. You best bet is to find a single hole plow or a newer style sleeve hitch.
Here is a picture of the later style stabilizer plate:
The one on the right is a Brinly stabilizer plate. The one on the left is one I made.
Keep up posted if you try making a set of stabilizer plates.
Project Uncle Dick
Cub Cadet 70
Old 10-23-2016, 09:29 PM
Default thanks
im new on here so im not sure on the picture posting. the plow is a factory brinly plow hitch. the wishbone old style hitch like in the picture above is what I got. there is about 3/8 inch of gap in front of the sleeve hitch to the brinly hitch when it is mounted . this lets the plow move sideways to either side.i made a l shaped bracket to take up the slack. I know there had to be a better setup from the factory. thanks for the help
Old 10-23-2016, 09:35 PM
Default plow set up
merk the pictures of your plow looks like a nice setup.my plow hitch is the newer 3 hole hitch. I guess the old hitch needs a old plow.i made a l shape bracket with a hole for the pin. it stops most of the side movement.if we every get out of this drought ill try to plow with it.thanks
Old 10-23-2016, 10:06 PM
You don't need another plow, you just need to limit the side to side movement.
Old 10-24-2016, 01:01 AM
Dale,
I did not know that there were sway blocks made for that style of hitch. Cool!
