54" Haban Plow, Lift bracket angle
The bracket that the lift arm attaches to is not welded square to the shaft. Nor the shaft or the flat section are bent. In the pic you can see the angle, and how the adjustment bolt is not in full contact with the frame.
Can anyone tell me if the flat stock piece is supposed to be welded on an off angle for a reason? The bolt head contacts the mule mount with only a short travel. To me it seems off, but before I create additional work I wanted to check to see if there is a reason its like this. Also, For this plow on a cyclops super (2182), which arm will I need to add to connect the rock shaft to the plow lift rod? Thanks Mike |
