Old 08-29-2010, 10:37 PM
ajgross
Maybe you should start a garden.. you know just to keep the tiller limbered up :biggrin2.gif:
Old 08-30-2010, 12:07 AM
Sounds like you guys have been busy!
Old 08-31-2010, 10:51 AM
To go here here
http://www.onlycubcadets.net/forum/s...ead.php?t=5607
I promised my wife once I got my 122 running I would clean the garage so we could start parking the van back in the garage. Well 122 is running just fine so I had to bite the bullet and clean the garage. Not only was I able to park the van in the garage again it gave me a chance to find most of my tools I'd lost in the move but provided me with more room to work on my cub.
I guess this plow day thing is a "good" thing after all.
Old 08-31-2010, 01:27 PM
Plow Day is worth it, Duke!
Old 09-01-2010, 09:45 PM
IHinIN IHinIN is offline
Today I worked on the dash tower on my 126. Someone had welded a new mount on for the clutch release arm and the way it was mounted the arm was too far forward at the top. I need to come up with a better way to mount it. Here's the bracket I cut off that was welded to the dash tower.
Here's the dash tower. The battery box had been cut off and tack welded back on. I grabbed hold of it and it came right off.
Here's a few before and after pics of the frame repair. Someone started to put a 14 Hp in it and the next guy "tried" to fix it but failed miserably.
Another pic of my engine stand. I can pull out a pin and rotate the engine 360* and lock it every 90*.
Does anyone know what the 1/4" wide slots are for in the dash and tunnel? I assume they are used on the hydro tractors.
Old 09-01-2010, 09:55 PM
mrcubcadet's Avatar
You sure did a great job on that frame! You can't tell anything happend on the outside!
-105___ Tiller
Old 09-01-2010, 11:03 PM
Those slotted holes are for the fan guard and hydro lever shaft.
Old 09-01-2010, 11:24 PM
Awesome job, Adam!
Old 09-02-2010, 10:00 PM
mrcubcadet's Avatar
Today, I got my tiller and put it on. I still need to get a NF belt because it came with a WF belt (if anyone needs a like-new WF belt make me an offer.)
-105___ Tiller
Old 09-02-2010, 10:08 PM
nickvanorman
Guest
Posts: n/a
wow those are some horrid looking welds. how they would hold anything is beyond me. looks all globbed on. no penetration. not even clean looking. haha. your a good welder though you can fix er up better than new.
