100 won't run wide open
Rebuilt carb. Applied initial idle and main jet settings, dialed in from there. Idles good, can't jam it all the way open but can slowly, operates good. have not checked head gasket but had it running wide open and no leaks. I also checked ignition timing via light. Pretty cool tractor just like to get running good, thanks
-Rick IH 782 IH 126 CCC 1863 |
Either it needs the timing adjusted, or the carb set more. Could be rich, could be lean. I can't tell you which because I'm not there.
My friend has a 1450 that did the same thing I believe you're describing. When we cleaned and rebuilt the carb we didn't pull out the main jet, only the needle. Afterwards, it would idle fine and run wide open only if we slowly opened the throttle. Go too quickly and it would stumble and die. Pulled the carb back apart and removed the main jet this time. Found most of the tiny holes around the jet were plugged. Cleaned the jet holes out and it ran perfect after that.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Adam, thanks for the great advice, that is exactly what I'm talking about. Going to check that first thing in the am. Bet it is the main jet
Got her running like a top. Main jet wasn't too bad. Went back and pulled points cover off and re verified my timing. Was off, got points to break at compression stroke and went from there. Purrs like a kitten and runs wide open no probs now. Thanks. This is a fun little tractor, an all original unmolested survivor, happy to add it to the collection
Your welcome
It is good you got it up and running.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
Good call Jon.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
BTW we really like pictures
