Old 02-08-2017, 09:43 AM
farmall fred's Avatar
farmall fred farmall fred is offline
Looking forward to seeing how this turns out. Just wondering how you make up new lines with the o-ring boss to fit the hyd valves on the cyclops series? In the back of my mind I have been hashing out some ideas for my 1872 project using a triple stack of hyd valves. Problem is making up all of the new lines that I will need. If I do this I can make the tilt steering from the 1864 work. Going to be a great tractor when you are done.
Old 02-08-2017, 01:09 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
You are just having WAY TO MUCH FUN.
Yes, yes I am! I have been watching you have fun on your 2264! Looks like a fun project
This is going to be cool!!
I sure hope so!! More over I hope it works
Originally Posted by DieselDoctor View Post
Having done all types of hydraulic work on aerial lift trucks for the last 30 years, I'm anxious to see this build! Sounds great!
Thank you! Im not a hydraulics expert, but do understand the basics. That along with my plumbing & refrigeration experience, plumbing and bending all the steel lines up does not scare me. Just hope it all works the way I want it to!
1- 1200 in pieces
1- 1864 in pieces
Old 02-08-2017, 01:17 PM
Rescue11's Avatar
My plans are to use the extra cyclops hydraulic lift lines i have purchased to go into the valves and cut the 1/4" rubber hose off so the full i.d of the 3/8" tubing is available for maximum hydraulic flow. My concern is all the straight couplings fitting nicely in that small of an area since I will have 6 of them to contend with.
They do make a tool that makes the orb fledge in steel line, but they are very expensive and I cannot replicate that tight of a bend right passed the connection.
1- 1200 in pieces
1- 1864 in pieces
Old 02-08-2017, 09:39 PM
I have used silver solder and a sleeve made from tubing that will slip fit the lines to extend some steel hydraulic lines on several of my antique farm tractors when I could not buy replacements or make replacements due to tight bends. might be an option for you. The sleeves could also be brazed to the tubing.
Old 02-08-2017, 09:57 PM
Have you considered tapping the valve block? I've looked at them and I think the hole is deep enough.....
Old 02-08-2017, 10:35 PM
Rescue11's Avatar
omg, i totally forgot silver solder!! Probably cuz i only use it for joining copper to steel, not steel to steel. Wow, that will make life so much easier. Thanks!
I have heard of guys doing this... in all reality would probably be the best route to take considering it would eliminate what i consider to be a poor excuse for a hydraulic connection. However, without putting a howlonger on the tractor, idk if it would fit? ... like be able to get the side cover on. Hell, ill do some checking on the tap size & if i have the right tap ill try it out on a crappier valve & then test it with 1200 psi of nitrogen
1- 1200 in pieces
1- 1864 in pieces
Old 02-09-2017, 01:30 PM
Rescue11's Avatar
Looky what showed up today!!
1- 1200 in pieces
1- 1864 in pieces
Old 02-09-2017, 01:39 PM
He got new rubbers!
Old 02-09-2017, 05:12 PM
john hall's Avatar
A toilet plunger?
Hey you can't say I didn't look at the pic.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 02-09-2017, 07:47 PM
Rescue11's Avatar
He got new rubbers!
rubbers... whats a rubber?
Originally Posted by john hall View Post
A toilet plunger?
Yes! Yes a toilet plunger lol
1- 1200 in pieces
1- 1864 in pieces
