Old 04-10-2017, 10:19 AM
i forget off the top of my head also the size of the bushing but its a common one like .5" ID and .75" OD.... i personally cut all the sleeves in mine, then i cross drill them right in the center and take a needle file and put a grease channel in them..then i put bronze bushings above and below the steel center, (readily available at any hardware store who stocks with hillman), and file the same grease channel in them...buy the proper length SS bolt put it in from the bottom and put split lockwasher and acorn nut on top, crank down..height of all three sleeves need to be a couple thou higher than the casting, (or same total height as original)..i pull out all the press in zerks too and tap them for .25"x28 also...usually 45* on those facing inwards...pic would probably help but its easy and not that much $ and way better than original, in my opinion....
