Old 05-20-2017, 06:59 AM
Series 1's are adjustable from factory
and ebay has $20-25 NEW ones that seem to have a good reputation.
While I can make non adjustable ones run as they should, I still don't like them.
They are lean to meet emissions.
Old 05-20-2017, 07:08 AM
john hall's Avatar
Now you got me wondering did the owner swap the series 1 carb over to the series 2, before that one blew? I do have a series 2 in a 782--non adjustable as well. That one runs OK, just needle isn't sealing--got to fix that.
I shouldn't say this, I have no idea whats on my 2072, but its been working proper since the day it got here!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-20-2017, 04:54 PM
BigB87's Avatar
BigB87 BigB87 is offline
well j mech i took it back down to nothing. knocked the welch plug out and there was some trash in behind and so i got that cleaned out. as far as the fuel filter goes i have a pretty big one on it and it flows pretty well without it running turn it over and it sprays like no tomorrow...i think the pump is good cuz when i took the line off it had pressure on it and squirted out of the line fromthe pump to the carb. im gonna give it another shot...if i cant i get it to run right this go around im gonna drain the fuel tank again and go from there
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 05-20-2017, 07:49 PM
If you found trash in the carb, I'd say that's your issue. Question is, did you get it all out....
Old 05-21-2017, 07:37 AM
BigB87's Avatar
I got it all out of the carb and also found out the emergency fuel shut off was bad (little plunger with the o ring) took it out and it has no issues now
Brandon
Old 05-21-2017, 08:17 AM
john hall's Avatar
OK, this is something I missed on mine evidently. Would you elaborate more on this please?
2072 w/60" Haban
Old 05-21-2017, 01:12 PM
You mean a fuel shut off solenoid? Mag engines don't have one .....
Old 05-21-2017, 02:39 PM
What are you talking about? Need a pic of this.
Old 05-21-2017, 03:12 PM
Mcamp Mcamp is offline
The last of the magnums had a fuel shut off,and the later replacement engines also came with the shutoff in the carb.1991 2082 with 435hrs pic. of shutoff.
Old 05-21-2017, 03:17 PM
BigB87's Avatar
Thats it. Unhooked and no more issues
Brandon
