Old 06-01-2017, 04:29 AM
cdlong's Avatar
cdlong cdlong is offline
Default 1450 hydro issue.
The last 3 weeks, it seemed the tractor was using more effort than usual to move. RPMs are 3600 by the tach. Yesterday, I was mowing and went to stop but the brakes didn't hold because the lever didn't return to neutral. I made another round and when I stopped to back up, the lever won't go into forward or reverse. I removed the tunnel cover and the linkage is trying to move, but the plate on the trunnion isn't trying to move. Hydro filter was changed this year. Trunnion was redone about 2 years ago. Thank God I have the auto valves and was able to push her home & into the shed.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 06-01-2017, 04:39 AM
Is there a question? Or were you just posting to tell us you had issues that you intend to follow up, on and post pics and detail the repair?
Old 06-01-2017, 04:53 AM
cdlong's Avatar
Question? Yes, anyone have any idea what happened and how to repair the ole gal? I'll get the fender pan off this morning and post pics.
Papaw
Old 06-01-2017, 05:05 AM
Well.... why don't you take the fender pan off, inspect the linkage, look things over and see if the issue isn't obvious before we spend a bunch of time posting the 10 or so possibilities that it could be, only for you to come back and say "Nevermind, it was a broken bolt" or something simple....
Old 06-01-2017, 08:02 AM
cdlong's Avatar
J-Mech, I's say you have a lot more time in repairing these old tractors than I do. I will remember your advise on what to do before posting going forward. Seems a pin in a clevis on the brake pedal rod came out. I couldn't / didn't see it when I removed the tunnel cover. The white conduit is pointing to it.
Papaw
Old 06-02-2017, 12:29 AM
There you go!!
