Old 06-22-2017, 11:06 AM
Beags86 Beags86 is offline
Default 782 getting hot
Hey guys, I have been busy using my 782 I picked up last fall.
Recently it started to surge after it gets hot.
I will mow for awhile and it it it start surging until it dies.
Then I can restart it and get another 10 mins out of it until it dies again.
I have found if I let it cool off it will run great.
A few days ago I decided to take the side panels off to see it that would help with the heat.
Sure enough I haven't had a problem since.
What gives?
What's the surging from? Vapor lock?
How do I get that to go away so I can put the side panels back on and mow on a hot day?
Old 06-22-2017, 11:08 AM
And because no thread is any good without pics..
Old 06-22-2017, 11:37 AM
The blower housing on the engine could possibly be filled with mouse nest.
Old 06-22-2017, 11:40 AM
Ok, I'll tear it down this weekend. And report back if I find anything.
Old 06-22-2017, 08:43 PM
Yep, give 'er a good blowdown. They need to have a lot of airflow to stay cool. Hopefully that's all it is.
Old 06-24-2017, 01:17 PM
Bsmith Bsmith is offline
My 782 acted very similar. Dying when it would get hot, then start back up when it cooled off. When I tried to start it when it was hot, it didn't have any spark.
I replaced the coil. I haven't had any issues since.
Old 06-25-2017, 07:37 PM
No mouse nests to be seen. It's been running better, but it's been cooler and I have been keeping the throttle down as well.
Old 06-25-2017, 07:38 PM
jimbob200521's Avatar
You want to mow at WOT (wide open throttle) as that not only gives you the best blade tip speed but also gives you better cooling for your engine. They were designed to operate at that RPM for mowing, take advantage of that
-Ryan
Old 06-25-2017, 07:41 PM
Well I get that, but it is run it at 3/4 throttle or mow and sit and wait....
Old 06-25-2017, 07:49 PM
Terry C's Avatar
Terry C Terry C is offline
Richen the top end.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
