Old 07-02-2017, 08:38 PM
Default Had better days with the 2372
Don't even start hacking on me. I feel bad enough already. NO ONE WAS HURT, in this catastrophe...
Just wanted to post, hoping no one will ever have this happen to them. And the worst part, well, maybe not the worst, think the tractor took the blunt of the worst. But this all could have been avoided, IF I would have used new prevailing torque lock nuts throughout.
Yeah, I used one older nut on the driveshaft flex disc joint, instead of all new one's. Why? I wish I had a good answer, call it lazy. Too lazy to go to town for one nut. I had three new one's, and that was it, so...
Installed a new driveshaft last week that my machine guy up here made, as my other one was worn out a bit on the ends. That all started when I needed to replace the seal on the pump, then noticed the driveshaft was in poor shape, so get a new one.
Haven't dug into it yet, that'll happen another day. So if anyone is replacing a driveshaft, OR anything in that area, don't reuse the nuts. This could be you...
Anyway, here's a few pictures of my mess. And HOLY COW, did that SOB make a racket when it let loose. Almost scared the chit out of me.
The 1650 is going back on lawn duty for awhile. Cause this repair is going to take me awhile.
Old 07-02-2017, 08:42 PM
jimbob200521's Avatar
Ouch! I'm glad you came out ok, I'd hate to think what a heavy shaft spinning at ~3600rpm between my legs could do to my...southern region in the seconds it'd take to turn the machine off.
-Ryan
Old 07-02-2017, 08:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Holy Mother Mary Todd, you are one lucky sob to still have your marble sack. Glad you didn't get hurt. Sorry to see you have a little work ahead of you. Good the 1650 gets to stretch its legs tho!
1- 1200 in pieces
1- 1864 in pieces
Old 07-02-2017, 09:12 PM
Glad your OK. Cub doesn't look too bad considering what happened.
Old 07-02-2017, 09:26 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
The damage is UNBELIEVABLE! I am glad you are ok.
Queen Of The Quietlines!
Old 07-02-2017, 09:28 PM
Dirty Steve's Avatar
Holy crap!!! Sure wrapped that hydraulic line up. Glad no one was hurt.
Old 07-02-2017, 09:29 PM
Dang Todd, that SOB tore some chit up! No one got hurt, that's the main thing. Good thing to have a nice backup grass cutter. Did it just grenade all at once?
I do have a question about what type of nuts to use. I use the grade 5 nylon lock nuts and grade 8 bolts from TSC and I think I put a dab of blue Loctite on them. Is it okay to use them in that application? Here is what mine look like.
Old 07-02-2017, 09:34 PM
Sorry to hear about the mishap Todd, I am sure it will be tended to in due time.
Oak, I use what cub cadet used, worked for them.
Up to 534 and counting...
Old 07-02-2017, 09:43 PM
cubs-n-bxrs's Avatar
Dang Zippy that's some carnage going on there. Glad you are OK. Never seen chit wound up around the driveshaft like that before.
Old 07-02-2017, 09:53 PM
john hall's Avatar
Yikes is all I can say. I've been using over the locknuts if I didn't have new ones. Pretty certain I have been using the kind with the dimple in the side. I need to check some of my stuff and make sure all is tight.
Sorry about the mower, but glad you are OK--that's the important thing!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
