Old 07-15-2017, 08:38 PM
Ronnie125's Avatar
Ronnie125 Ronnie125 is offline
Default Another QL followed me home!
I just picked up this 1250 for $100. It is missing the muffler and PTO; however, I'm only going to use it for parts for my other QL tractors. I already have plans for the engine. It is going to repower my smoking 1250 until I rebuild the engine. I do love my Quietlines!
1975 1000 | 2 snow blades (1 power angle)
1979 1100 | 6 44a decks, 1 38" deck
1977 1200 | Brinly cultivater & moldboard plow
1978 1250 | qa42 snow thrower, IH landscape rake
1975 1250 (parts tractor)
1977 1450
1976 1650 with dual remotes
2007 Husqvarna 2348
Old 07-16-2017, 02:38 PM
Riley Henderson's Avatar
Riley Henderson Riley Henderson is offline
I love mine too I try to go start mine and run them around whenever I can if your like me your parts machines will quickly multiply. But once you have them you will be suprised how much you san scavenge off of them they seem like they are worth more than what they can be bought for. Very good buy on on the 1250
Old 07-16-2017, 06:51 PM
Ronnie125's Avatar
Yup, I was just out in my barn with my tractors. My 1000 has a leaking axle seal and the the shifter cup needs repaired. The project would have moved along faster if IH would have used bolts instead of big phillips head screws on the foot rests!
1977 1450
2007 Husqvarna 2348
Old 07-17-2017, 07:32 PM
twoton twoton is offline
Originally Posted by Ronnie125 View Post
I just picked up this 1250 for $100.....
Can't go wrong there, good deal!
Old 07-17-2017, 10:54 PM
Yes sir those big screws on the footrests are a real bugger to get off everytime I have took them off there is at least one or more that need drilled out I usually replace them with bolts.
Old 07-18-2017, 09:17 AM
Ronnie125's Avatar
Uh huh! I had one on each side I had to drill and that was after a week of soaking in PB too! New bolts for me too.
1977 1450
2007 Husqvarna 2348
Old 07-18-2017, 10:41 AM
Terry C's Avatar
Terry C Terry C is offline
They make impact screwdriver sockets for 3/8 drive I'm sure cause I have a set. That's how I get them off.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-18-2017, 03:45 PM
Ronnie125's Avatar
I may have to invest in some. Good to know.
1977 1450
2007 Husqvarna 2348
Old 07-18-2017, 07:44 PM
Wack the head of the screw with a chisel the same size as the screw head, then they come off for me with a BFSD.
Up to 534 and counting...
Old 07-18-2017, 08:09 PM
OldSkull's Avatar
OldSkull OldSkull is offline
I heat them and off they goes...A bit of sanding and a spray can touch up job, good enough for those old turd!
PS: I use stainless steel button head socket bolts like those David Kirk sell, get them from a local motorcycle store.
Gilles.
1963 100 (red)/in storage
