Old 07-27-2017, 03:50 PM
Chucks ss Chucks ss is offline
So let me ask you this when you pull the lever back and that little button presses against the clutch housing or whatever you call it. that disengages the clutch??
Old 07-27-2017, 04:01 PM
Terry C's Avatar
Terry C Terry C is offline
Yes.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-27-2017, 06:43 PM
Update. A littke tightening of the turnbuckle and its working good. Im mowing my grass. Love this thing. Thanks gyys. Now on the the fuel bowl on the left side. The little needle adjustment. Any help? Motor runs. But seems lick might be starved for fuel a little under load.
Old 07-27-2017, 07:20 PM
That little "adjustment needle" on the sediment bowl is a fuel shut off valve
It is more handy than a pocket on a shirt, for cleaning the bowl/screen without draining the tank, or other fuel system work.
A couple or 3 turns open is all you need.
Old 07-27-2017, 07:53 PM
Ankney. Moved here from illinois 12 years ago. I love iowa.
good move (out of Illinois) I wish I could afford the same move... somewhere outta here.
Old 07-28-2017, 10:23 AM
I live in a suburb outside des moines if u can afford illinois. U can afford iowa. Still small town living here even in big citties. Love this place. Update *** so after running the mower i realized i had a head gasket leak. So went to case IH dealer picked up a new one and a carb kit. Just because. So after work today i hope to be running again
Old 07-28-2017, 10:31 AM
Terry C's Avatar
After you plane the head flat and put that new gasket on, you won't know it's the same engine. It will run so much better.
Terry
3225
Old 07-31-2017, 12:00 AM
Gompers Gompers is offline
Ah cool! I'm on the south side of DSM.
Old 07-31-2017, 09:39 AM
You guys need to plan a trip to Charles City Labor Day weekend.
The IA Chapter #5 is holding their "summer show" there in conjunction with the Cedar Valley Engine Club annual show. We plan on a "Cub Cadet Corral" display area and you DO NOT need to be a member to show or attend. Should be a great weekend!
More info in the Show and event section.
