Old 08-01-2017, 10:04 PM
Default Lawn mower carb help on a Corvette forum
Sometimes you got to sit back and wonder what they were smoking/drinking/banging their head against.
Originally Posted by poster 1
If there are issues with the passageways, he's going to have to readjust anyway. Most times, there is a standard setting that can be found online and minor adjustments can be made from there.
Originally Posted by poster 2
Correct. The usual rule is 1.5-2 turns open to get it to crank, then adjust to fine tune after carb is fully warmed up.
And a "turn" is not a 360deg rotation. More like 180deg
Ohhhh, my head hurts
I'm staying out of this one
Old 08-01-2017, 11:50 PM
cubby102's Avatar
cubby102 cubby102 is offline
Most likely a predominant efi vette page? Ain't no way In heck they are gonna be able to tune a q-jet :/
Old 08-02-2017, 08:42 PM
The guy with the problem had a newer Corvette, the guy offering help is a street rodder.
What I found most humorous was that a turn wasn't really a turn.
Old 08-02-2017, 09:21 PM
mortten mortten is offline
I'll bet it will crank with the screws fully closed. Probably won't run though.
Doug
QA-36A
42" blade
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Same here, but I understand. When I tune a carb, I count in half-turns. If I count to 5, it's 2.5 turns tho. Clear as mud right?
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 08-02-2017, 09:39 PM
But what he implied was the 2-1/2 turns YOU end up with would be 1-1/4 for him
Luckily he didn't have to get into the carb. Fresh gas "allowed" it to run.
Old 08-02-2017, 09:45 PM
Internet is full of wannabe mechanics. Nothing surprises me anymore. Still gives me a headache.... but doesn’t surprise me.
Old 08-03-2017, 11:21 AM
DieselDoctor's Avatar
What gets me the most is the ones that will argue that they are right and everyone else is wrong. They are superior and all the rest are just idiots.
Old 08-03-2017, 01:18 PM
There's a lot of idiots.....
