Old 11-28-2017, 11:30 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Not sure what kind of rivet you use but mine wouldn't break.
Tim.
Rivets carefully install with the right pressure for the material used are almost indestructible, just think about how many "G" a airplane can be submit
without falling apart in flight! But like welding there is the good way and the wrong way to do it.
Gilles.
1963 100 (red)/in storage
Old 11-28-2017, 12:11 PM
Ok, well if you put a rivet every 2" like an airplane, it would hold even with cheap rivets, but who wants to drill all those holes!
I'd use self tapping sheet metal screws before I drilled holes and put rivets in. But, that's my opinion.....
Old 11-28-2017, 12:44 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I suggest pre-painted aluminum sheets for your skin.... such as the kind used on race car bodies. The aluminum are available in many different colors Pop rivets are easy... use a good step drill or a sharp twist bit. It'd be real nice in install the plexi-glass, polycarbonate or even tempered glass with some kind of molded H shape rubber if it could be had (I'm sure you can....just got to look around).
Plow blade
#2 Cart
QA36 snowthower
Old 11-28-2017, 02:05 PM
OldSkull's Avatar
Wait a bit Jon and be ready to hit the trigger....Someone may soon suggest "Velcro" and another one will reply with JB weld! LMAO
Gilles.
Old 11-28-2017, 02:19 PM
Stephen.Mellish's Avatar
Stephen.Mellish Stephen.Mellish is offline
You forgot duct tape......
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
Old 11-28-2017, 02:22 PM
OldSkull's Avatar
G....I was keeping that one for a later post with the tie-rap and the $6 HF tarp. Now you give the punch dam it!
Gilles.
Old 11-28-2017, 05:20 PM
willys55's Avatar
willys55 willys55 is offline
A few people think it is too tall, did you get your measurement by sitting in the seat? I know that being 6'3" I tend to build things taller than normal....
64 Cub Cadet 100
Also have quite a few Non Cub Cadets in the Shed
Old 11-28-2017, 06:09 PM
john hall's Avatar
I thought about that or canvas, like the old Heat Houser windbreakers for farm tractors use--assuming you can still buy them. Doubt the canvas matl would like getting wet.
In all seriousness, there are some pretty high tech adhesives nowadays, but they probably cost way more than a bunch of bolts/rivets/spot welds/tack welds.
To the OP, nice looking job so far. Keep us posted on your progress. I'm sure whatever you box it in with will be just fine. Now I think a big ol' LED lightbar across the top and a flashing strobe on the top would be the icing on the cake!
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-28-2017, 10:15 PM
Being a glass guy, my go to adhesive is Automotive Urethane. Its a structural adhesive and its fairly cheap. You could go with sheet metal on the solid areas and I would use 3/16 to 1/4" lexan on the windows. You could use the urethane and rivets to put the lexan on just like the sheet metal. Use a primerless urethane if you go that way. Feel free to PM me if you want more info.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 11-28-2017, 10:33 PM
If you adhere the windows with urethane, I don't see why they would need to be riveted. Urethane holds the big glass in auto's and even tractors (much more surface area of glass). May need to add a ledge or a lip for it to sit on at least on the bottom. You agree Randy?
