Old 12-13-2017, 09:21 PM
athomas's Avatar
athomas athomas is offline
Well it's really a 20 footer ! I did a little touch up on it but at some point in it's life someone took some hateful grit sand paper to it and slopped on some brush paint I think still looks good till you get up close and you can see the results of someone's quick do over .
Old 12-13-2017, 10:55 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by athomas View Post
Just an update to the 129's broken hydro thread , with the help of JohnCub7172 in the way of a set of used slippers and retaining ring ( for a great price ) +++ and some new gaskets the 129 is up and running again. New hytran fluid and filter, reset neutral, no leaks no drips, freed up the relief valves while it was out and repaired the drive shaft couplers, expect it to run another 40 years !!!
Very Nice!! glad you got it working with recycled parts and didn't have to spend too much.. sometimes satisfaction of knowing you didn't take the easy way out is worth the extra trouble!!
Jay
Proud owner of the following:
Old 12-14-2017, 01:42 AM
johncub7172's Avatar
Cool
There are not many parts and components that come together to form these awesome IH Cub Cadet garden tractors that can not be rebuilt, before being replaced!
Also, with the parts I sent, you know what you have, where a used pump could be a 50/50 crap-shoot in the real world where deals don't normally exist. You also got a terrific deal on a spare pump
Old 12-14-2017, 07:33 AM
jbrewer's Avatar
jbrewer jbrewer is offline
John, that's to me the primary draw to these old machines. They were meant to last and to be repaired when something wears out. The sheer number of survivors is testament to that. It's mighty nice of you to help out as you did and I'm really glad another one is being used again!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 12-14-2017, 09:48 AM
sawdustdad's Avatar
Just to pile on, I replaced a few pistons/slippers on a hydro a couple years ago in a restoration. They fit in the cylinder block nicely, and it's back in operation and works fine. Can't say it will last another 40 years, but for my purposes, it was the expedient thing to do. On another project, I did buy a used hydrostat, and it's working fine, too.
If I were building or repairing a unit that was intended for 40 years of heavy use, I'd follow the mfg instructions not to mix up pistons/cylinders, etc.
Old 12-14-2017, 10:14 AM
sorner's Avatar
sorner sorner is offline
Nice job... if I had a quarter for every time I was told not to do something because it's not the right way, or the manual says not to do that, I'd have at least 75 cents profit (because I spent the rest on curing my yellow fever ). I rebuilt a power steering cylinder a while back by cutting it open with a hacksaw, replacing the seals, and putting it back together... against all advice and everything. I've used it quite a bit and no problems yet. If you're careful and doing the job with good sourced parts, you can squeak by with undocumented/not recommended repairs.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
