Old 12-14-2017, 10:21 AM
OK Tim,
Why do you have a dual stick 1650?
Up to 534 and counting...
Old 12-14-2017, 10:25 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
I'm surprised you didn't read my post and then ask me about why I have a 1650 dual stick here.
Do you mean these?
Tim, LOL...pictures or didn't happen! Is it yours or a customer's?
Lew...Yes...However, the earlier ones I believe, had metal caps rather than the plastic. Do you have NOS set of them?
Queen Of The Quietlines!
Old 12-14-2017, 10:27 AM
No I do not, but these do!
Pics or it didn't happen Tim!
File Type: jpg ema3-1-4npt-parker-diagnostic-fitting.jpg (14.6 KB, 94 views)
Old 12-14-2017, 10:29 AM
Dirty Steve's Avatar
Ouch! These look like the caps which would go on the male cylinder side connection.
https://www.ihccw.com/dualhydro.html?product_id=364
This pic shows a kit with the caps.
As far as the caps for the tractor side?
This could give you a starting point. I have not found a Cub part number anywhere yet.
https://tinyurl.com/y9kldbsy
Old 12-14-2017, 10:30 AM
It belongs to someone else, it's here for me to rebuild the engine and replace some seals in the rearend along with some other misc work.
Old 12-14-2017, 11:23 AM
Dirty...
The part # for the caps are 106361-C1
Old 12-14-2017, 10:48 PM
My dual stick has the rings behind the collars, in front of the frame...
Well one does, the other is broke.
Old 12-14-2017, 10:58 PM
DeltaCub's Avatar
That is correct...My mistake...I was going by memory from eons ago!
Old 12-15-2017, 06:57 PM
TOPDOWNRESTO TOPDOWNRESTO is offline
Todd,
Would you be kind enough to post a close up picture of the cap and coupling ?
I have original couplings and they are pulled flush with the sheet metal when the snap ring was installed from behind. I am still confused about the set up originally.
Thanks
Carroll
' 68 125 '75 1650 dual stick
