Old 01-22-2018, 09:45 PM
Originally Posted by dirtcowboy View Post
it may pull a little harder but not anywhere near that I'm worried about blowing the rearend out of tractor. I just stay smart with it, plow with it for spurts at a time and then let it sit and let rearend cool down.
You worry too much. You aren't going to hurt that rear end. You don't have enough weight on it to. Now, if you don't have rear end braces, you may bust the pump housing.... so if you don't have them, I'd find a set and install them.... make your own, whatever. The 982's were bad about cracking the frame too. But the rear end..... NO. You aren't going to overheat the hydro either. You will know if it starts getting too hot. It will slow down and so will the hydraulics. I've not seen one overheat yet.
