Old 01-27-2018, 11:06 AM
drcjv's Avatar
drcjv drcjv is offline
Default Starting problem
On my 2072 the blue wire going into the back of the plug on the ignition switch seems to be loose. The tractor does not crank. If I push on wire it cranks. I have cleaned the plug and also put some dielectric grease but I still have to push. Whats the fix.
Charles________________________
1572 3pnt, rear PTO, 50" deck
1772 3pnt 50" deck, Brinly Plow, 54" Power angle plow
1872 3pnt, 44" deck, Brinly Plow, 54" Power Angle Plow
2072 3pnt 50" deck, Brinly Plow
2072 50" deck
Cub Cadet Tank 50 Zero Turn
Cub Cadet 33" Commercial Walk Behind
1953 Ih Cub with just about every implement
New Holland TC33D with Loader and Backhoe
Old 01-27-2018, 11:10 AM
CubDieselFan's Avatar
They are not that expensive, I would just replace it.
Old 01-27-2018, 12:01 PM
drcjv's Avatar
It is not the switch it is in the plug.
2072 50" deck
Old 01-27-2018, 12:26 PM
No, it's the switch. Loose terminal. When you push on it it makes contact.
Old 01-27-2018, 12:28 PM
ironman's Avatar
ironman ironman is offline
You need this....
https://www.ebay.com/itm/Replaces-Jo...19.m1438.l2649
or this....
https://www.ebay.com/itm/Key-Switch-...8AAOSwCU1YzUCo
Old 01-27-2018, 03:09 PM
I should have been more clear, he was talking about the plug so I just thought he would think I meant to replace the plug.
Old 01-27-2018, 03:32 PM
drcjv's Avatar
Jonathan I thought the same thing so I pulled the switch out of my other 2072 which works fine and I have the same issue. If I put a little pressure on the blue wire just behind plug it cranks. Then I put the switch from the one not working into the second 2072 and it works fine.
2072 50" deck
Old 01-27-2018, 03:44 PM
Those Ebay deals are pretty good. I like the one with the pig tail.
I purchased these before.
https://theelectricaldepot.com/weath...ctor-br-5-pack
https://theelectricaldepot.com/weath...als-br-25-pack
Old 01-27-2018, 05:27 PM
john hall's Avatar
Got to be a bad connection between the terminal and the wire. Get it apart and crimp/solder it.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 01-27-2018, 05:51 PM
Fair enough. Get a pigtail then!
