The TAX Man Will Feed My Family, This Year!
Every year, I try to add some sort of compost to the garden,,
so, my my wife mentioned she had tax documents to get rid of,,, She mentioned firing up a burn barrel, or find a shredding facility,, I figured the worms would love the paper,, Newspapers have been a favorite worm food in past years,, I figured the worms would LOVE my tax records. I opened a furrow with my rotary plow, I guess any plow that turns over a furrow would work; Then I laid the documents in the furrow about one inch thick; Next, I used the plow to cover the documents; I sprinkled some high nitrogen fertilizer on the documents to promote decomposition; I needed 3 furrows to get rid of all the records,, here it is after the last furrow was plowed; Over the next 36 hours we are supposed to get 2 inches of rain,, that should soak the paper well,, Maybe I will plant corn and use the tax man's records to grow what I need to make untaxed moonshine!! LOL! |
That's a good idea. Make sure you post your results.
Paper/cardboard is also good to keep the weeds away. Just put it between your plants, and keep it wet so it doesn't blow away.
125, 126, 147, 129, 149 x 2, 1450, 882, 1810, 1320, 1440, 2135, 2 129’s for parts/project, 1950 Farmall Cub 38" LT mower deck, 4 42" triangle mower decks, 2 44A mower decks, 2 50C mower decks, 42” GT deck, 3 42" snow/dirt blades, 42" landscape rake, #4 cart |
Newspapers have more BS in them, that's why the worms like them so much.
Did you put the papers in chronologically just in case you need to dig up a certain year? |
there is never anything at all left the following season. I expect the same results with this,, the worms will love dining on important documents!! |
I purposely randomly put the documents in the trench,, to confuse tax auditors, if they show up tomorrow,, Actually, we still have the records, on digital storage,, I was amazed how far back we had the digital records,, if the CD's and jump drives are readable,, Some of it is stored in cloud storage,,, I think,,, |
Growing deficit? Do we really need anymore?
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
My neighbor has done that for several years as well, he uses bagged shredded paper from the office at work and can get all he wants for free.
Recently, when he digs his potatoes in the fall, they already have baking and storage instructions imprinted! |
Good recycling!! You can also weld a rod onto a bent up old circular saw blade. Put your papers down into a 5 gallon bucket, add enough water to cover them. Then chuck the rod into a power drill and shred up a lot of papers real fast. Cut a piece of wood in a circle to fit into the bucket, drill some holes in the side of the bucket and then press the wood down into the bucket to squeeze as much water out as possible. Turn the bucket over and allow the shredded paper to air dry or sun dry. It won't start a fire, but if added to one, then it will burn for a long time. So you could use your old tax docs, junk mail, or whatever to help heat your home if you have a wood stove.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. |
I love it John! Especially since you used the Gravely.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
