Old 05-09-2018, 01:47 PM
bsm2003
Guest
Posts: n/a
Default Differences in Rear-end gearing if any.
Have a 2182 the bolts holding the rear-end to the frame are busted out. Found a cheap 1440 with what appears to be a pristine rear-end (IE-not busted out where the bolts that hold it to the frame are.)
Is the gearing the same for a direct swap? I will be doing the SamMac mods and new gaskets and seals. Just wanting to clarify that the gearing and such are going to be the same. Don't have a problem swapping them out if need be.
Thanks in advance.
Scott
Old 05-09-2018, 01:56 PM
Terry C's Avatar
Terry C Terry C is offline
Thanks in advance.
Scott
Supers are geared different. Not a direct swap.
Rear end braces do wonders
Sam will be along shortly to help, he’s the expert
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-09-2018, 02:28 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
The 1440 has a Hydrogear trans and a 2182 has a Sundstrand trans. The reduction housings are different. So I hope you didn't buy it yet.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 05-09-2018, 02:43 PM
bsm2003
Guest
Posts: n/a
All I really need is the axle housings. They should I hope bolt up to the 2182 housing.
Old 05-09-2018, 02:55 PM
Shrewcub's Avatar
Sorry, I misunderstood. I thought you meant the front mounts. Axle tubes are the same.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1961 IH Cub Cadet O
Old 05-09-2018, 03:08 PM
bsm2003
Guest
Posts: n/a
That's what I thought. Just wanted to confirm that was the case.
Thanks.
Scott
Old 05-09-2018, 03:56 PM
Yep tubes will swap, axles will also work. diff should play. While you have it apart drill some oil return holes in the main case. I also recommend a set of Xtreme SGT rear end braces.
Here is some light reading for you.
http://www.onlycubcadets.net/forum/s...ad.php?t=33244
Old 05-09-2018, 03:57 PM
sorner's Avatar
sorner sorner is offline
Do you have it apart yet? There's a chance the holes in the main housing are broken too, or stripped, or bolt(s) broken off.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
Old 05-09-2018, 05:56 PM
bsm2003
Guest
Posts: n/a
Don't have it apart yet. After about 6 months finally getting started on it. But it will be coming out next week. I know for sure the axle tubes are broken out where the frame bolts go. those are visible with a little light shining into the bolt holes.
Old 05-09-2018, 05:58 PM
bsm2003
Guest
Posts: n/a
I have your threads bookmarked. Been reading and studying off and on over the last few months when I haven't been remodeling the house or repairing things for my dad.
Tags
1440, 2182, rear-end, super mods, swap
