Old 08-02-2018, 08:28 PM
Kjamesm's Avatar
Kjamesm Kjamesm is offline
Thanks guys I appreciate the help, is there anyway in its current state with the shifter off and the gear fork loose inside to move the teactor into neutral?
Old 08-02-2018, 08:34 PM
cooperino's Avatar
Normally yes. Is the piece you broke jammed? Send a picture if you can.
Old 08-02-2018, 09:31 PM
Yeah, tighten the bolt on the fork and just slide it into neutral.
Old 08-02-2018, 11:27 PM
Originally Posted by cooperino View Post
I would buy this one before your forced to spend 130$ on a new old stock.
https://www.ebay.com/itm/CUB-CADET-1...sid=m570.l1313
While used is likely fine, you can still buy new ones. Not from CCC.... but they are still made. They are less than $130 too. But more than $50.
OP:
If you really did break the 1st/rev fork, you have to take the trans out to fix it. The 2/3 shift fork is bad about bending.... 1st/rev not so much. I've only seen like 1 break, and it was on a tractor the clutch was out of the owner was jamming it in gear.
Old 08-05-2018, 12:42 PM
Kjamesm's Avatar
Finally had some free time last night. Pulled the tranny out which was shockingly straight forward, pretty obvious what to do from here. While I have it out though I wanted to try to fix a possible clutch issue ive been having hoping anyone has some insight of where to start looking. So when I have the tractor usually only in 2nd or 3rd gear and I'm driving a longer distance after a bit I hear this loud rattle that sounds like glass in a jar. When I push the clutch in about an inch it goes away. I had previously tried adjusting the clutch thinking there was just some slack and it was vibrating but that didnt solve it. Also thought maybe it was just the pedal vibrating and I'm an idiot but I wrapped a hand towel around the pedal as a test and the rattle was no where near the actual paddle and stopper. Theres alot of play in my clutch disc, the 3 holes are egged out alot could that be the rattle?
Old 08-05-2018, 02:06 PM
Yes, the egged holes can rattle. A bad support bearing can cause the clutch not to be centered and cause a rattle. You need to just pull the clutch assembly and inspect it. Sounds like a rebuild is in order.
Old 08-06-2018, 05:46 PM
Kjamesm's Avatar
I'll add that to the list. With the transmission sitting on my bench I spun one wheel forward as it was freed up now and noticed the other one spins the opposite direction....so Is it stuck in two gears or something why would they spin in opposite directions all the sudden?
Old 08-06-2018, 05:50 PM
Normal differential action through the spider gears.
Old 08-06-2018, 11:47 PM
......I spun one wheel forward as it was freed up now and noticed the other one spins the opposite direction....so Is it stuck in two gears or something why would they spin in opposite directions all the sudden?
Old 08-07-2018, 07:31 AM
The Skylark has an open differential and anybody who's ever been stuck in the mud in Alabama can tell you, you step on the gas, one tire spins, the other tire does nothin.
