Old 09-12-2018, 06:20 PM
Timmy1 Timmy1 is offline
Default Cub Cadet 1862 spark plugs
Hello, newbie here from Norther Illinois. Hoping this is the proper way to start a new thread, anyways I'm working on a 1862 with an 18 horse Magnum that I picked up while cruising the countryside. Found on side of road with free sign. Has weak spark and noticed it had 2 different plugs. RS14YC and on other side Autolite 26. Both were gapped @ .045 Online manual says Spark plug #759-3334 and should be gapped at .025. I tried cross referencing the Cub part number and I've gotten 3 different plugs. Can somone point me to the right direction. Thanks
Old 09-12-2018, 09:09 PM
cooperino's Avatar
For what worth...
Here's the link also
http://www.tractordata.com/lawn-trac...72-engine.html
File Type: jpg Screenshot_20180912-210816_Samsung Internet.jpg (16.8 KB, 78 views)
Old 09-12-2018, 09:13 PM
Welcome to OCC,
in out technical section you can down load the service manual FREE.
It should answer most of your questions.
(RV17YC @ .035)
Old 09-12-2018, 09:31 PM
After my reply I see the discrepancy you saw.
My info is from the Kohler service manual.
For what it's worth, experience says both gaps/plugs will work fine.
Old 09-12-2018, 09:46 PM
I thought it took RC plugs.... but I was going off memory.
I gap mine to .035" and run it. +/-.005" won't make much difference.
If it has weak spark, it likely needs a new magneto. (Ignition "module" according to the parts book.)
Old 09-13-2018, 10:45 AM
Service bulletin #265
Up to 534 and counting...
Old 09-13-2018, 04:13 PM
Glad you found that service bulletin and thanks for all replies. Now I can move forward on this. Now I need to be sure that incorrect plug that was on one side did any damage (RS14YC, threadreach is 6.3 mm longer than oem plug) Most likely will need ignition module (weak spark). I tried downloading the service manual in the technical section, there is none for the 1862.
Old 09-13-2018, 05:04 PM
You need the engine sevice manual. It's in the tech section. The chassis manual doesn't cover the engine.
Old 09-13-2018, 05:33 PM
The 1862 had a Kohler M-18 in it. In the Tech Library Section, is the M-18 Service Manual.
Old 09-13-2018, 07:17 PM
Please bear with me, where is the tech library section? You mean the Cub Cadet parts and service look up? Top of page? Thanks
