Old 09-19-2018, 09:53 PM
Ikea6e Ikea6e is offline
Default 3000 Series reverse speed
Hi,
Is there a good way to increase speed in reverse without decreasing forward speed?
My sister has a 3225 that will barely move in reverse.
Thanks,
Ike
Old 09-19-2018, 10:07 PM
dale c. dale c. is offline
the bushings on the pedal shafts wear and can cause that problem , there are 2 different sizes... the linkage is also adjustable for length has 2 bolts and the hole is slotted right under the foot board
Old 09-19-2018, 11:05 PM
TNTs CC TNTs CC is offline
There is a second adjustment located under the floor pan in between the frame rails. The last three 3000 series tractors I've bought has required this adjustment to be made since the two bolts had come loose.
Basically the best way is to replace any worn bushings and adjust the linkage at both locations.
3240 870hrs - 48" 289 deck, front hitch, 3 hyd circuits, 54" blade w/hyd angle, 45" 2-stage snow blower, Sims cab, 5 42# suitcase weights and 70# rear wheel weights
GT3204 207hrs - 48" 289 deck, 45" 2-stage snow blower, 54" blade and angle cylinder
3204 580hrs - 48" 289 deck - Parts Tractors - 3208 560hrs (rusty) 3 hyd circuits, 3pt hitch, 44" deck - 3165 rust free roller
1650DH 54" blade, Xtreme cat-0 3pt, 44" deck, filled 23x10.5-12 Tru-Powers
Old 09-20-2018, 06:32 AM
Oak Oak is online now
Reach down and pull up on the forward pedal while backing up. If this increases your reverse speed then you probably have worn bushings.
Old 09-20-2018, 07:35 PM
Thanks for your inputs guys.
Off to the Big Apple tomorrow to see our son.
Hope to get over to my sisters next week to check It out.
Thanks again,
Ike
Old 10-08-2018, 01:41 PM
Pulling up on the forward pedal definitely increased the reverse speed. New bushings are on order.
Thank you for the tip.
Ike
Old 10-28-2018, 02:21 PM
New bushings installed. Got reverse. ;-)
Old 10-28-2018, 04:16 PM
Just love "happy endings" and thanks for reporting the results
