Old 11-17-2018, 10:45 PM
DieselDoctor's Avatar
Looks like you're off to a great start Jay! First road test is always fun.
Old 11-18-2018, 06:28 AM
Thanks for the update. Looking good.
Old 11-18-2018, 07:16 AM
twoton twoton is offline
Good to see your progress.
Old 11-18-2018, 08:14 AM
IHCubCadet147's Avatar
Looks good!
Old 11-18-2018, 08:47 AM
john hall's Avatar
Looking good! Hopefully no surprises on the hydro.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 11-18-2018, 11:01 AM
Looking great Jay! That is one nice machine.
Power steering & a Command in an 82 series.
Old 11-18-2018, 07:40 PM
Coming along there mr. jeep, keep us posted on your progress.
Up to 534 and counting...
Old 11-18-2018, 09:08 PM
sawdustdad's Avatar
It's Alive!!!
https://youtu.be/1qNeGSJaQ9Q?t=154
Old 11-19-2018, 12:10 PM
That's awesome, Jay!
Old 11-19-2018, 03:40 PM
nophun nophun is offline
Originally Posted by jaynjeep View Post
Well I re drilled the KT plate as per directions on here by others that have done this conversion... everything fits and works now!.. Guess I have a nice 1641/1864 plate now if anyone needs it!
I used 1/2 inch spacers under the engine as the 1864 does... looks like the driveshaft runs uphill toward the engine? Wonder if I should use it without spacers? Any suggestions?
Allow me to comment on this and share some knowledge that was imparted upon me as a whippersnapper hot-rodder:
The driveshaft has to have an angle so that the needles (balls in this case) will roll and move the lubricant around. In the case of a car, the needles could fail because the stress was being put on a single one instead of sharing the load between the set.
Another way to look at it is, lets say, the contact point between the balls and the carrier is a 1mm circle, if the balls don't roll, then there's know way for the lube to get into the contact point which will accelerate wear. Now, if the balls are rolling as little as 1mm in each direction because of the angle, you've tripled the contact surface and cut the wear factor by 1/3, plus the grease is flowing. (1mm figure was arbitrary).
It always made sense to me.
