Old 11-29-2018, 03:13 AM
hemimike hemimike is offline
Default Tire Suggestions Please??
Looking for tires for my 3205. Want something good in mud and snowblowing my driveway. Doesn't cut grass anymore so no concerned about ripping up the lawn or anything. Front tires are 16x7.5-8 and rears are 24x10.5-12.
Old 11-29-2018, 03:23 AM
cubby102's Avatar
cubby102 cubby102 is offline
Chain up. Works well in mud and ice/snow
Old 11-29-2018, 04:31 AM
I'm running chains right now and it's tearing my driveway up pretty good. Plus when my buddy had it, he got stuck a few times.
Old 11-29-2018, 04:50 AM
ejl6658 ejl6658 is offline
Carlisle All Trail, 23x10.5-12, Carlisle All Trail II ATV Tire - 25X1100-12 LRB/4 ply, Carlisle HD Field Trax 24X12.00-12/2 Tire. Unfortunately Carlisle don't come in your exact size. Using wheel weights or filling tires with washer fluid or rv antifreeze will help with traction but only chains work well on ice. Going with large rear tires could also cause problems with interference with gas tank if you add chains. As far as the front, 16x6.50-8 V61 HD 5-Rib 170/60-8 6 ply will do the best for turning but are expensive.
Old 11-29-2018, 06:30 AM
Unfortunately, that is an "odd" size (24x10.50-12) in the L&G tire world.
IF....you are looking for an Ag Type of tire, here is what Carlisle offers: Carlisle Ag Tires
Miller Tire Company has a lot of Lawn & Garden Tractor Tires. You might want to check them out.... Miller Tire
Old 11-29-2018, 07:30 AM
Default Tire suggestions
I have a GT 3200 with a 45" blower. I have the 25X11X12 Carlisle All Trail II tires filled with RV antifreeze and wheel weights. Does real well. Clearance for chains would be tight with the gas tank but with the diff lock as well I've never had a problem.
Old 11-29-2018, 08:00 AM
CC2140 CC2140 is offline
Default Go Dully
https://i.ytimg.com/vi/MK9-ZnWU8_Q/hqdefault.jpg
Old 11-29-2018, 08:09 AM
Default Tracks
https://i.pinimg.com/564x/a6/f1/27/a...f9a27dd83d.jpg
Old 11-29-2018, 08:12 AM
Billy-O's Avatar
Billy-O Billy-O is offline
They make rubber tire chains....
some examples:
https://rubbertirechains.com/
https://www.superior-tech.com/rubber-tire-chains.html
Disclaimer: I never tried them
Plow blade
#2 Cart
QA36 snowthower
Old 11-29-2018, 08:13 AM
Default Convert to half track
https://youtu.be/dP910gY0kKE
