Old 11-29-2018, 07:32 PM
Jeremy_K Jeremy_K is offline
Default 450 impeller shaft
I'm in the process of tearing down my 450 snow thrower. Is the shaft that goes from the impeller to the front auger gear box supposed to be sloppy? I have the impeller with the shaft still roll pinned in place and it has a lot of slop in it. Just didn't know if this was normal. I'm probably going to be buying a new impeller since mine is heavily bent and the splines in back are shot.
Old 11-29-2018, 08:22 PM
I can not say, but if I was to venture a guess, I would be inclined to think....no slop.
Old 11-29-2018, 08:48 PM
And I would have to agree 100%, splines are made to be a snug fit.
Old 11-29-2018, 09:19 PM
The splines appear to be separate from the shaft. There is no movement of the spline while moving the shaft.
Old 11-29-2018, 09:24 PM
mhbtsc mhbtsc is offline
Have you priced that impeller?
Old 11-29-2018, 10:26 PM
$171.84 on Amazon
Old 11-29-2018, 10:27 PM
Originally Posted by Jeremy_K View Post
$171.84 on Amazon
You can fix a lot for $178.....
Old 11-29-2018, 10:40 PM
You mean if I had a welder and machine shop? Or if I knew how to weld or machine things? The impeller splines are all but gone. The impeller fins ingested a frozen 2x4 last winter so they're not looking too good either.
Old 11-29-2018, 10:50 PM
Or took it to one of those places.....
