Old 12-20-2018, 11:51 AM
Seekertom Seekertom is offline
Default Dija Know This??? re: runtime clock.
I wonder if I'm the only one who found this fact eye-opening....
I tried starting my new cubby lt50, but discovered the key was on (I blame the grandkids... Always blame the lil kids, right?)
Battery was of course, totally dead. I jumpered from a spare and it started right up, but I was shocked to see hour meter at 52 hours! I checked my phone cam archives and saw last use time was 2.7 hrs. WTF????
So, here's what I learned about the run-time clocks.... they don't necessarily track engine run time... the clock runs any time the key is on.
Surprise to me.
Maybe not a big deal, maybe all the world's clocks are the same, but I have to wonder how a guy can be assured that the clock really represents tru engine run time... I also wonder if anyone else already knew this???
st.
thanks for all the input, folks. Ya, do have grandkids, even great-grandkid, ifn ya want to count my semi-scottish daughter and her sub-clan...
n e how, my concern was because my 'other' cubby had a blown engine and somehow it seemed significant that the engine showed only 020 hours runtime. Now, it seems, I have nothing to wave about the air in my complaints since the hours dont mean diddly!
o well. Merry Christmas, y'all!
st
Old 12-20-2018, 11:53 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
That's why I probably will hook the hour meter into the charging system, so that when the key is left on all it does it burn up the coil instead of adding hours on.
My 1250 is hooked up that way, and so I know that the hours are correct.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 12-21-2018, 06:45 AM
Leadslingingdaddy's Avatar
So you are willing to burn up a coil rather than just clock time on an hour meter????
From the kid that can't afford nearly free tractors and equipment???
You can eliminate this issue by installing a battery shut off switch that manually disconnects the battery from any device or gauge on the lawn mower...
Old 12-21-2018, 06:51 AM
cooperino's Avatar
I think most of the guys here know the clock runs if key left on. I had a green one once that th PO installed a single led light on the dash that lit when the key was on. It didnt shine on anything nor was it bright enough to use to see anything really. But it did let you know the key was on from distance.. wonder if the PO had grandchildren
Old 12-21-2018, 07:00 AM
Yup, I have known this for a couple of decades.
Old 12-21-2018, 07:32 AM
Hour meters are as reliable as odometers, and the people that set them back.
I group them with lawyers/politicians.
If one wires them through an oil pressure switch,
( on engines that have an oil pump) then they will only operate when there is oil pressure of a running engine.
Old 12-21-2018, 09:43 AM
Mudrig150's Avatar
Either way it would burn up the coil, right?
Old 12-21-2018, 10:03 AM
Old 12-21-2018, 03:45 PM
Gompers Gompers is offline
Tractor basically already has one - the keyswitch.
Old 12-21-2018, 07:48 PM
Bamafan Bamafan is offline
Inactive Member
I eliminate the switch being turned on accidently, I take the key out and hang it on a nail out of the grandkids reach.
[B]Larry[/B]
Tags
cub cadet mower, lt50, runtime clock
